Brief background, I studied physics in college and am learning EE on-the-job through Art of Electronics and this wonderful website.
So this is a follow up to a previous question I submitted here yesterday. I was trying to see what could have gone wrong when I wired a bunch of devices in parallel and then ran them under-voltage. In the comments, I was informed that I should pay attention to P = IV in that the devices I'm using will try to maintain a fixed power rather than respond according to V = IZ.
I'm not entirely clear on this so I was hoping someone could enlighten me as to what kind of circuit could be drawing more current in response to less voltage. I always understood current and voltage to be proportional on a fundamental level, regardless of the load, since the voltage is the energy source. But, if we take the fluid flow analogy, perhaps there's some sort of "thinning of pipes" when a lower voltage is applied.
How does a circuit pull more current when it doesn't get the voltage it wants with respect to a constant minimum power?
What kind of circuit keeps a constant power?
  • \$\begingroup\$ Active control electronics. A boost converter, for example. \$\endgroup\$ – Hearth Feb 14 at 16:32
  • \$\begingroup\$ @Hearth Sweet. This put me on the right track. Boost and buck converters. \$\endgroup\$ – lbman Feb 14 at 18:48
Imagine a universal power supply that works in multiple countries that have different mains voltages, just like the one that is used to charge a mobile phone. Let's assume the phone requires 5V at 1A so it draws 5 watts of power when charging. Let's also assume the power supply is made of unobtainable ideal components so it does not consume power itself, so it will always take 5 watts from the mains socket when charging. So as power drawn by the supply is constant, it means it draws double the current from a 110V mains socket than it would from a 220V socket.
  • \$\begingroup\$ So that's an example of the mechanism but do you know what this kind of circuit might be called? \$\endgroup\$ – lbman Feb 14 at 18:47
