I am trying to implement AES in verilog using 32-bit data path, but I am not able to subsitute the 128-bit in just four clock cycles, my code requires five clock cylces, Here is the small portion of code;
assign initialXorKey = addroundkey(plain_text,cipher_key);
assign mixOut = mixw(r0_new,r1_new,r2_new,r3_new);
assign shiftRow= shiftrows(mixOut);
always @(posedge clk or negedge reset_n)
begin
if(!reset_n)
begin
   count<=0;
   subCount<=0;
end
else
begin
  sboxIn<=sboxNext;
  subCount<=subCount+1;
  if(subCount==2'h3)
     count<=count+1;
end
end
always@ (*)
begin
   case(subCount)
     2'h0: begin
           if(count==0)
              sboxNext=initialXorKey[31:0];
           else
              sboxNext=shiftRow[31:0];
              r3=sboxOut;
              r0_new=r0;
              r1_new=r1;
              r2_new=r2;
              r3_new=r3;
           end
     2'h1: begin
           if(count==0)
              sboxNext=initialXorKey[63:32];
           else
              sboxNext=shiftRow[63:32];
              r0=sboxOut;
           end
     2'h2: begin
           if(count==0)
              sboxNext=initialXorKey[95:64];
           else
              sboxNext=shiftRow[95:64];
              r1=sboxOut;
           end
     2'h3: begin
           if(count==0)
              sboxNext=initialXorKey[127:96];
           else
              sboxNext=shiftRow[127:96];
              r2=sboxOut;
           end
endcase
end
since the new value on right hand side register in is reflected on the next clock cycles, the output of S-Box comes on next clock cycle, since it a recursive process (i.e after fourth clock cycles I have to run the Subsition for the next 128-bit which depends also depends on the current subsituted 128-bit). I am bounded to do it in only four clock cycles and people did it. I am not sure how to fix this, but help is greatly appreciated.
  • \$\begingroup\$ this may not make any sense ..... my understanding of what you are trying to do is limited ..... but, logic reasoning tells me that you need to do more "work" during each clock cycle in order to fit everything into 4 clock cycles ..... perhaps a pre-fetch of some kind, so that in one of the clock cycles you are using 64-bit data \$\endgroup\$ – jsotola Feb 15 at 6:26
  • \$\begingroup\$ There is no clock in this code. How can we count clock cycles? Can you write pseudocode or C or python for the operations you are trying to perform? \$\endgroup\$ – Elliot Alderson Feb 15 at 12:33
  • \$\begingroup\$ You likely registered the output in another part of the code... or delayed the input, or an enable, etc. Draw out your design (probably ok to not worry about the combinatorial logic details for your first draft) using FFs... waveforms will be helpful too... and you will more than likely see the issue appear before you. \$\endgroup\$ – CapnJJ Feb 15 at 17:16
  • \$\begingroup\$ @ElliotAlderson Sorry I forgot to add that line in the code, I have edited the code, No you can see clock in the design. \$\endgroup\$ – Sajid Khan Feb 17 at 9:51
