A three wire source has differential output but uni-polar(only one signal wire varies wrt AGND). Ground wire is AGND, the the other two is signal SG and the reference SGref. I'm trying to amplify the transducer signal with a gain of ten by using a non-inverting amplifier.
Since the transducer is not single ended output I'm bit confused. Which topology is correct?
At page 41 here shows the differential wiring of channels and at page 37 it says:
The transducer outputs are designed to work with a differential input to the DAQ system for best performance. Transducer outputs are ground-referenced differential signals. The output impedance of each DAQ signal is 100Ω
(I checked the output and only SG moves wrt to AGND but not SEGref so I think it is unipolar even though differential ended)
  • \$\begingroup\$ Try simulating it and add common-mode noise equally onto both feed wires via a 1 nF capacitor. \$\endgroup\$ – Andy aka Feb 15 at 12:25
    \$\begingroup\$ It's better to use an opamp connected to amplify differentially when you're using a differential source. \$\endgroup\$ – Neil_UK Feb 15 at 12:28
    \$\begingroup\$ @Neil_UK Do you mean differential amplifier like this topology circuitstoday.com/wp-content/uploads/2011/11/… ?? \$\endgroup\$ – user1999 Feb 15 at 12:29
  • \$\begingroup\$ Which transducer (datasheet) and what is your DAQ ? \$\endgroup\$ – Marko Buršič Feb 15 at 13:42
  • \$\begingroup\$ First circuit will create contention between the feedback and the input signal. I think the second one is the correct option. If you want to use both the differential outputs of the transducer use fully differential design, otherwise an amplifier without feedback. \$\endgroup\$ – sarthak Feb 15 at 14:05
