-1
I am trying to repair my set of Bose QC25s and I need to buy more cable in order to do so. I am not sure which type I need specifically. The cable looks like this:enter image description here
It appears to have 4 conductors, 3 of which are coated in enamel insulation and 1 that is bare copper. The diameter of the outer insulation is 2mm, while the inner conductors are ~0.5mm in diameter.
My searches on electronic suppliers with these parameters have not been successful.
If you know what type of cable this is, I would be very happy to know!
  • \$\begingroup\$ Welcome to EE.SE, your question appears like a repair based question. Change your question such that it should appear more like a part identification based question as repair questions are off-topic here. \$\endgroup\$ – Electric_90 Feb 16 '19 at 4:25
  • \$\begingroup\$ that may be special highly flexible cable ..... the photo that you posted is not very good (should be covering only 6 squares, not 50) ...... the individual conductors probably consist of a bundle of non-conductive fiber with wire wound around the outside of the bundle ..... these are a pain to solder properly .......... google ultraflexible miniature cables \$\endgroup\$ – jsotola Feb 16 '19 at 8:03
  • \$\begingroup\$ maybe you can install a headphone jack into the headphones and then use a patch cable to connect the headphones \$\endgroup\$ – jsotola Feb 16 '19 at 8:12
  • A lot of audio devices use these kinds of wire.
  • These wires are simply known as Enamel Wire / Magnet Wire.
  • In your case it is a 4-pole enamel wire (see this).
  • Also, take a look at this hackaday post.
