I am studying patch antennas for mobile communication (technology.)
I have found some examples of them but without explanation.
Maybe can someone explain to me the difference of examples from this picture?
my thoughts:
c) Is a patch which is connected with a waveguide (or linear antenna.)
f) With a folded slot
But I am not sure, that' s why I need your help.
  • \$\begingroup\$ All of these are PIFA, a type of patch antenna. \$\endgroup\$ Feb 16, 2019 at 12:38
All these are not microstrip patch antenna but all these antennas are mostly fed with 50 ohms coaxial line (or SMA connector).
  1. Option-C : This is inverted Wire antenna.
  2. Option-d : This is Inverted-F wire antenna
  3. Option-e : This is microstrip version of inverted-F antenna also called PIFA (Planar inverted F-antenna)
  4. Option-f : It's also microstrip PIFA antenna with a slot cut on this. Slot is used to generate another resonance frequency (multi-band antenna)
