I'm confused on where I went wrong finding \$ \zeta \$ (zeta) and \$ \omega_0\$. I think its where I originally did nodal at Avx. Any help would be appreciated.
-thanks
  • \$\begingroup\$ \$ s^2+2.5s-1.5\times 10^5\$ cannot be correct because the negative term renders the TF unstable. All the coefficients of a 2nd order TF must be +ve for stability. \$\endgroup\$
    – Chu
    Commented Feb 18, 2019 at 8:27
My simple analysis
Since V(L)=LdI/di = "Vx" is in series with A*Vx for A=4 , then R damping voltage sees (1+4=5) or 5*L as effective inductance.
Since Ic=CdV/dt = "Iy" boosted by B*Iy, for B= 3, then the circuit produces (3+1 = 4x) or 4 effective capacitance multiplier.
So the \$L'=5L,~ C'=4C,~~~~~ L'C'=10^{-4}= 5*2.5mH*4*2mF\$
I know that I can apply here \$\omega _0=\dfrac{1}{\sqrt{L'C'}}=100 ~rad/s \$
Z(L') @ ωo =2π100 rad/s 2.5mH = 1.571 Ω at resonance
R=50Ω is higher than Z(ωoL) in parallel with the current source so underdamped <<1
Damping Coefficient = ζ =0.0125=α/ωo=1.25/100 using your value for α
