I need to generate pulse in one pulse mode and measure width of this pulse using HAL. I'm using STM32F446RE board. I managed to configure timer to generate pulse but I have no idea how to implement pulse measurement. I found that it can be achieved with input capture but i couldn't find any example.
Here is my timer config:
void MX_TIM5_Init( uint32_t timerPrescaler, uint32_t timerPeriod, double timerPulse)
  TIM_MasterConfigTypeDef sMasterConfig;
  TIM_OC_InitTypeDef sConfigOC;
  htim5.Instance = TIM5;
  htim5.Init.Prescaler = timerPrescaler;
  htim5.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim5.Init.Period = timerPeriod;
  htim5.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  if (HAL_TIM_PWM_Init(&htim5) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  if (HAL_TIM_OC_Init(&htim5) != HAL_OK)
  if (HAL_TIM_OnePulse_Init(&htim5, TIM_OPMODE_SINGLE) != HAL_OK)
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim5, &sMasterConfig) != HAL_OK)
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = timerPulse;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  if (HAL_TIM_PWM_ConfigChannel(&htim5, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
  sConfigOC.OCMode = TIM_OCMODE_TIMING;
  if (HAL_TIM_OC_ConfigChannel(&htim5, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
  HAL_TIM_MspPostInit(&htim5);
There is an example in the STM32F446xx Reference Manual in section 18.3.6. It uses one timer to capture the time of the rising edge and another to capture the time of the falling edge. This mode is typically used to decode a PWM encoded input.
| improve this answer | |
