-5
i want get 20mA current with 24V ac to dc. I have found this power supply module with 6-9A output current but i need max 20mA. What can i add with this module to achieve my settings?
I am powering medical tool so output current must be max 20mA because sometimes the patient have to touch so If i wamt to be safe it must be max 20mA constant output current.
Product description - enter image description here
  • \$\begingroup\$ Please edit your question to explain what you are powering. Do you want constant 24 V (constant voltage) or constant 20 mA (constant current). And where is the 24 V AC coming from? \$\endgroup\$ – Transistor Feb 19 at 19:37
  • \$\begingroup\$ Please read Choosing power supply, how to get the voltage and current ratings? and if you still have questions, come back and edit this post to clarify what you need to know. \$\endgroup\$ – The Photon Feb 19 at 19:42
  • \$\begingroup\$ I see you have the 4-20mA current loop for something like industrial controls. Your selected approach is not a good starting place for either a sensor/transducer or a receiver. \$\endgroup\$ – W5VO Feb 19 at 19:48
  • \$\begingroup\$ 150mV ripple may need a filter then you may have CM noise issues. What is this for? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 19 at 20:07
  • \$\begingroup\$ why do you need to use that particular module? .... it is surely an overkill \$\endgroup\$ – jsotola Feb 19 at 21:18
6
I am powering medical tool so output current must be max 20 mA because sometimes the patient have to touch so If i wamt (sic) to be safe it must be max 20mA.
No, for medical devices you don't use cheap power-supplies like this. The risk of harm is too great. Judging by the nature of your question you are not qualified to carry out this work.
  • \$\begingroup\$ You cant judge this topic i need the solution. The device will be controlled by experts before production. \$\endgroup\$ – Nikayout Feb 19 at 20:23
  • \$\begingroup\$ @Nikayout Why not ask the experts for advice? \$\endgroup\$ – user253751 Feb 20 at 0:16
  • \$\begingroup\$ @Nikayout If they are experts and they see you use this in a medical application, they will reject it. Don’t even start down that road. \$\endgroup\$ – DoxyLover Feb 20 at 2:43
