My LG monitor (25UM65-P) has original adapter (19V, 1.7Amp), can I use a different adapter (14V, 2.14Amp) for it? Has this any side effects or negative points?
closed as off-topic by Bimpelrekkie, Voltage Spike, Warren Hill, Elliot Alderson, Finbarr Feb 21 at 17:39
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Bimpelrekkie, Voltage Spike, Warren Hill, Elliot Alderson, Finbarr
If this question can be reworded to fit the rules in the help center, please edit the question.
While the current available @ 2.14A is high enough - the voltage at 14v will be too low and it will likely not work.
If connected correctly it is unlikely (but still possible) to cause damage though since it is a lower voltage. If the connector is wired incorrectly however it will probably fry it in short order and could pose a safety risk.
So if you aren't sure what you are doing I would not recommend trying this.
