I'm starting out with I2C. I have a development board with stm32f103c8t6 to which I have connected GY-68 board with BMP180 barometric pressure sensor. Documentation of BMP180 describes Chip-id register [0xD0] which holds a constant value of [0x55] and can be a good way of testing if the I2C communication is working.
I am trying to read this register, but my code does not work. I am not sure if my setup is correct, because neither the BMP180 address nor register addres seem to be transmitted.
The board has an external clock set to 8MHz which I am confident is setup properly, because I have working UART which I use to check if the registers are set.
I have calculated CCR and TRISE with this instructions
void initI2C()
RCC->APB1ENR |= RCC_APB1ENR_I2C1EN | RCC_APB2ENR_IOPAEN;
GPIOB->CRL |= (1 << 31);// Set pin B7(SDA) to alternate out open drain max 10MHz
GPIOB->CRL |= (1 << 30);
GPIOB->CRL &= ~(1 << 29);
GPIOB->CRL |= (1 << 28);
GPIOB->CRL |= (1 << 27);// Set pin B6(SCL) to alternate push pull max 10MHz
GPIOB->CRL &= ~(1 << 26);// I have also tried open drain
GPIOB->CRL &= ~(1 << 25);
GPIOB->CRL |= (1 << 24);
I2C1->CR2 |= 0x08; // Set clock to 8MHz
I2C1->CCR = 0x28; // Set CCR
I2C1->CCR &= ~(1 << 15); // Sm Mode
I2C1->CCR &= ~(1 << 14); // Duty cycle for Fm mode
I2C1->TRISE = 0x09; // Set clock rise time
I2C1->CR1 |= 1; // Enable peripheral
I2C1->CR1 |= (1 << 8); // Set start bit
while (!(I2C1->SR1 &= 1)) // Wait for start condition generated
{} //Never passes
I2C1->OAR1 = 0xEE; // Set Address
I2C1->DR = 0xD0; // Set address of id register
while (!(I2C1->SR1 &= (1 << 1))) // Wait for end of address transmission
{} // Never passes even with above while commented
while (!(I2C1->SR1 &= (1 << 6))) // Wait for data register not empty
{} // Never passes even with all above while commented
Now I know I don't read the register value here, but the the start condition never is generated, the address is never transmitted and the data register is not transmitted. I am reading some activity on both SDA and SCL pins with my multimeter, but I don't have oscilloscope to check exactly.
Any help would be appreciated.
