I see these connectors inside a microwave oven and other home appliances. They are installed on the ends of wires and have round edges, while the middle section is flat. What are they called and do splitters exist that split one such connection into two? Thanksenter image description here
    \$\begingroup\$ A trade name is "Faston" \$\endgroup\$ Commented Feb 21, 2019 at 6:43
Spade connectors. Often used in cars too.
  • \$\begingroup\$ Many times a spade connector is attached with a screw. I have seen spade terminals and fork terminals used interchangeably to refer to the same thing. It is more common to refer to these as FASTON or quick-connect. See digikey.com/products/en/connectors-interconnects/… \$\endgroup\$ Commented Feb 21, 2019 at 17:10
Yes, they do make splitters. They look like this sometimes:splitter
You will often find these on the electronics site referred to as angled or flag quick connects. enter image description here
You will find splitters and male to females often listed as terminal adapters.
enter image description here enter image description here enter image description here
