13
Doing some research in selecting capacitors for high frequency applications, concept of equivalent series inductance comes up a lot. Apparently all capacitors have this parasitic inductance which appears in series with the capacitance of the component. If the ESL is high, in high frequencies this inductive reactance can even cancel out the capacitive reactance, and the cap essentially acts as a resistor which blocks DC.
But why is the ESL so significant? Sure, caps have wires, but I would imagine the rest of the circuit has much more wire and therefore much higher parasitic inductance which would be much bigger problem than the short component leads. Otherwise caps are just plates with a dielectric in between, so what is it about them that causes us to worry about ESL so much?
When it comes to electrolytic capacitors, I found one explanation: It was explained that as the cap is basically a long piece of foil rolled, there is definitely a lot of inductance since the roll of foil acts kind of like a coil. But I don't think this makes sense at all: It's not like the current travels along the foil! The current builds up an electric field in one foil, which again produces a current in the other foil. But this field appears across the foils, not along it, so this explanation makes no sense to me.
So could somebody explain this phenomenon to me, preferably in the context of both ceramic and electrolytic capacitors?
    \$\begingroup\$ Are you treating displacement current as not "real" current? \$\endgroup\$ Feb 22, 2019 at 23:28
14
disclaimer: while I appreciate OP have accepted my answer, in lieu of the (currently) most voted answer from Peter Smith, please be sure to also read his, as it is very clear and helpful. click here!
Ceramic caps and electrolytic caps have very different characteristics, and are used for very different things.
Ceramic caps have very low ESL, usually a few 100 pH for a reasonably small, modern package. An electrolytic cap ESL is much bigger than that.
In a similar way, a ceramic cap capacitance is much lower than an electrolytic cap.
Those two facts put together lead to a very big difference in the resonant frequency of the cap. An electrolytic cap resonates at a few 100 Hz, while a good ceramic resonates at a few MHz.
The electrolytic caps are usually used when you deal with low-ish frequencies, such as power supply smoothing or audio application.
The ceramics are used where you cannot compromise on the frequency response, so for high frequency filters, or to filter out the supply of a digital, high frequency device such as a micro controller.
As you say, the circuit is made of wires, usually longer than the cap leads. This is true, and it is why a ceramic cap is usually placed a few mm away from the point it must filter/supply. A few mm on a PCB, depending on track width, is easily a few 100 pH of inductance, so you are doubling what the cap is providing.
At high frequencies, the cap does not act as a resistance, but rather as an inductor, and its impedance grows with frequency.
About where the inductance comes from, I am not sure if it is possible to get an intuitively satisfying answer. You say the current is not travelling across the foils, but this is not true. They are at the same potential and current does not travel along them only at DC. What happens at 1 MHz? And 1 GHz? Some current is surely flowing also through the foils.
Ceramic are much better, they are built like a double comb:
https://upload.wikimedia.org/wikipedia/commons/thumb/6/6e/MLCC-Principle.svg/1920px-MLCC-Principle.svg.png link to source
In this way, the "longest path" is much shorter, thus the parasitic inductance is much lower. If you look at ESL for ceramics, you will find that the figure depends almost only on package size, the smaller the package, the lower the ESL.
    \$\begingroup\$ Electrolytic Caps would be very unusual to resonate at several 100 Hz. I believe a standard figure of their ESL is 10 nH which puts their SRF in the ballpark of 100s kHz. However, their large ESR prevents any self resonance unless sizable external inductance is present. \$\endgroup\$
    – tobalt
    Oct 27, 2021 at 18:07
25
When current flows, there is by definition a magnetic field around it. This leads to self-inductance for any conductor with a varying current.
As a capacitor is a low impedance at AC (the precise amount depends on frequency of course) then a real capacitor looks like this:
C1 is the nominal capacitor, R1 is the equivalent series resistance, L1 is the equivalent series inductance and R2 is the leakage resistance.
You will note we now have a damped series resonant circuit; below self resonance it is capacitive, at resonance it is resistive and above it is inductive.
The value of ESL depends on both the materials and the size of the device; for a reverse geometry device in a 0204 surface mount package it might be as low as 300pH; a typical 0402 surface mount ceramic is about 680pH.
For decoupling and coupling devices this matters in a high speed world.
Let's do a quick calculation. If I am decoupling a device that has internal switching rates of 200 picoseconds (not at all uncommon and has frequency artifacts at 2.5GHz) and I use an 0402 0.1uF device, then the actual impedance is about 4.3 ohms and it is inductive.
You did read that correctly; the capacitor is now acting as an inductor.
Typical surface mount ESLs:
0402 680pH: 0603 about 900pH: 0805 about 1.2nH
A 1 inch track at 4 thou (quite common) has about 5nH of inductance, for reference. This is the reason decoupling devices need to be so close to the actual power pin being decoupled. A device that is even as little as 1/2 inch away at these frequencies may as well not exist.
The inductance for a PCB trace assumes it is over a plane; the precise value will vary based on distance to the plane (because it impacts total return path and round trip time). I have found the value above to be a good (conservative) starting point for PCB designs. The actual inductance is specifically dependent on total current path distance for the loop.
So the reason for ESL? Physics.
    \$\begingroup\$ +1 for first paragraph alone -- that is the key concept here. \$\endgroup\$
    – Dave Tweed
    Feb 22, 2019 at 13:53
  • \$\begingroup\$ @ Peter Is that 1 inch track above a Ground plane? given the useful rule of thumb of "1 nanoHenry per inch of wire" (ignoring the mild log contribution), I'd expect a 1 inch track IN AIR, not near any sizable plane, to have 25 nanoHenry. The reduction from 25nH to 5nH ---- if near a plane ---- that 5:1 reduction, is about what I've been using for wire-over-plane for years. Again, your statement "has about 5nH" is for that 1" trace, 0.004 wide, is OVER A PLANE? \$\endgroup\$ Feb 22, 2019 at 14:15
    \$\begingroup\$ @analogsystemsrf - answer updated; over a plane. \$\endgroup\$ Feb 22, 2019 at 14:25
  • \$\begingroup\$ @ Peter Thank you. I will start using 5:1 reduction (over a plane). \$\endgroup\$ Feb 22, 2019 at 14:38
    \$\begingroup\$ This issue is why I switched from EE to computer engineering. I checked out a book from the library, "The Art of High Speed Digital Design: a handbook of black magic." Chapter one described this effect. My response: "screw that!" Now I get to program the computers after someone else figures out all these counterinutitive details for me! \$\endgroup\$
    – Cort Ammon
    Feb 22, 2019 at 18:21
-1
To answer - Try to draw two foils in spiral shape with electrolite/insulator between them. For AC current - there is vector D and current flow trough insulator (displacement of charge) and when you draw current directions trough foil area or just in 2 dimension (in cross-section), you'll see how nicely becomes coil shaped structure. So there is an inductance. Even two straight parallel wires have inductance. Even one wire in the air have inductance. So small, but it exist.
  • \$\begingroup\$ obviously wrong, since the retrace follows the same spiral in opposite circularity. The ESL of electrolytics is cause because they are tall and have widely spaced leads. So the current loop from lead to core to lead is the determining factor (for all caps) \$\endgroup\$
    – tobalt
    Oct 27, 2021 at 18:12
  • \$\begingroup\$ Sure! Leads are part of connection to foils. But, did I say that leads should be neglected!? Current (AC) will flow trough one lead into foil spiraling and dividing trough length of the foil/area of the foil crossing electrolyte, into another polarity foil, summing back into second lead and way out of capacitor. Alternating back and forth. So, yes you could look at the structure as just one big current loop, but dimension of the loop is bigger when you take into account internal structure of the capacitor versus taking into account just dimension of cap and lead spacing. \$\endgroup\$
    – msimunic
    Oct 28, 2021 at 9:44
