I'm trying to implement a UART receiver that works by finding a '\0' in the datastream, OR when it receives 256 characters at which point the data should be processed by an interrupt. The point is to use DMA for reception but if either of these events occur it should stop filling up the current buffer and process the data. The reason is that I'm using COBS encoding to frame my data.
The STM32F7 chip has something called Character match as part of the Modbus specification, which I got working by setting the bits in the configuration register since it's not supported by the HAL(stm32cubemx, which would remove this code upon regenerating) libraries:
MODIFY_REG(huart->Instance->CR1, UART_CR1_FIELDS, tmpreg | USART_CR1_CMIE);
And at the end of the UART interrupt handler I do
UART8->ICR |= USART_ISR_CMF;
To clear the character match interrupt flag so it won't run again.
As I understand it the interrupt handlers in the STM32f7xx_it.c are in fact the first functions
void DMA1_Stream6_IRQHandler(void) and void UART8_IRQHandler(void)
in my case that are run as interrupts occur in a peripheral, and from these functions a handler(HAL_xxx_IRQHandler()) is run that check what interrupt occurred and run any user defined functions depending on the interrupt flags, like for example:
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *UartHandle) {
//process data, this runs when DMA finishes receiving bytes
The problem is that it's not clear which one of the interrupt function is ran when for example I'm using DMA and I have received my specified amount of data over UART. Does it run the UART interrupt or the DMA stream interrupt? How can I reliably end up in the same callback function on '\0'(uart?) or 256 bytes(dma?) to process my data without botching the interrupts?
