Our company has designed a board for a custom SoC network processor. It has a PCIe gen2x4 interface, with a PCIe PHY.
This PHY's PLL requires a 100 MHz reference clock. We are using the reference clock from host PC which is acting as RC and SoC is acting as EP.
We are able to lock PLL on some SoCs after doing some settings in the PHY registers and also able to get the link up (although linkup do not happen on 2x4 every time on the PC start up, but after enabling and disabling the LTSSM two or three times, it gets linked up to 2x4.), but some SoCs don't get locked with same register settings.
Then we reduce the bandwidth of PLL by decreasing the charge pump current. By doing this we are able to get PLL locked if PC is on and PLL is getting 100 MHz clock.
After this, we power off both PC and board.
Now for linkup we power on the board (EP) first and then PC (RC). But now PLL is not able to lock and therefore no linkup happens.
We have measured the RMS cycle to cycle jitter with SoC mounted on the board, in time domain which is coming around 18 ps.
PCIe gen2 spec says that RMS jitter should be around 3 ps. But they specify this jitter for some particular frequency range like 10 kHz to 1.5 MHz and 1.5 MHz to Nyquist (=Refclk/2).
- So are we not meeting the specs or we have done the wrong measurement?
