Since travel by bike a lot, and use my phone very often during those trips, I tried designing a USB phone bikecharger that would use my bike-dynamo that also powers my lamp.
Yesterday, I did my first tests. Without load, the circuit would give me 9,3V (even when the wheel was not spinning, which was a surprise to me :) ). With a 47 Ohm load, it would still give 9.3V. This is way too much for USB ofcourse, but 47Ohm is still quite big I think.
When a 10Ohm load was applied (I assumed 5V USB-voltage, 500mA charge current --> 10 ohm), the voltage dropped to 3,5V (it kept quite stable, it didn't fluctuate all that much. It seems the wheel speed doesn't influence the output voltage, except for when it spins too slow and the voltage is cut off entirely. I assume this is some kind of protection mechanism in the dynamo?).
So here's my question: what would happen is I were to attach a phone to this charger?
My guess is that 3.5V is not enough to overcome the internal resistance of the phone battery threshold for the charge circuitry of the phone, so it will be blocked a few ms, but because of the open circuit, the voltage will rise to 5V and that will eventually be enough to charge. So in practice, it will just charge with a lower current (same as charging your phone on the USB-port of a netbook. Those often can't provide enough current, and the phone just charges slowly).
Is my guess right?
What are the risks of charging a phone-battery with too little voltage?
Should I worry about the charger outputting 9V when the phone battery is full? Because there won't be any load anymore then.
Thanks in advance!
ps. I also checked the signal with an oscilloscope to check the purity of the DC, and it was pretty clean. There were no big spikes and the level was quite stable. (I didn't try to pitch pennies on noise-supressing capacitors ;) )
Edit: added my schematic
EDIT2: J3 in the schematic is an LM2596 Buck module, using a MP1584 step-down regulator module.
EDIT3: I was doing some tests a few minutes ago, and I guess I had misconfigured the LM2596 (doh...). I think the 9.3V issue is not existent anymore (I've only tested it on a bench power supply right now, but I assume it'll be the same when I test it on my bike again). So now the only question that remains: Is there any risk to applying a voltage too low to the phone? And will my above assumption hold true?
EDIT4: Currently testing it with some old phones, with my bike on a treadmill. 5V is constantly stable now for every speed above 6km/h, and charge current is 300mA, also pretty stable (100mA on an older phone). The phones themselves also indicate that they're being charged At first glance, everything seems to be working, but... the charge percentage is barely going up. I'm not sure yet if this is because the batteries are very old and haven't been used in ages, or if there's still something wrong with the circuit. More testing will be needed ;)
EDIT5: as pointed out by @Ale...chenski the path between the rectifier bridge and the two elco's is wrong and will be removed.
