I need to create a pulsed current variable from 0 to 20A to run solenoid with a very low resistance. Which is the best solution for you?
Right now I am trying to generate a pulsed current with Labview using a NI-USB 6009 device, which will give me an output of 0,2 A and 5 V. I have been told that I could use an active amplifier to transfer the output signal of the USB to an higher current. Is this possible? which kind of instrument I could use for this purpose?
Thank you
  • \$\begingroup\$ Which is the best solution for you? I do not need this so it is unclear to me why you are asking me which solution I like best. \$\endgroup\$ – Bimpelrekkie Feb 26 at 9:17
  • \$\begingroup\$ I don't think an amplifier is the right tool. You want a solenoid driver that you can control using the signal from your NI-USB 6009. \$\endgroup\$ – JRE Feb 26 at 9:49
  • \$\begingroup\$ Could you please explain further how the system should work? \$\endgroup\$ – Luca Granelli Feb 26 at 10:20
