I have a problem with layout design of pad. After creating the netlist and doing the routing, I want to add some single long pads to the board without packages to be able to solder wires on these pads. I have used the pad stack editor but I could not import into the PCB designer. It saved as a .brd file. Is there a way to create different pads shaped directly on the OrCAD PCB designer?
  • \$\begingroup\$ Use a 1 Pin Header in your schematic file, assign it a footprint, attach it to a net and it should show up. \$\endgroup\$ – Tyler Feb 28 at 15:32
