From my last question, I've managed to connect my Atmega32u4 to my computer.
Now, when attempted to initialise the bootloader using avrdude, I get the following error message:
j4cob-antergos :: ~ » sudo avrdude -p m32u4 -P usb -c flip1
avrdude: Warning: USB bDeviceClass = 255 (expected 254)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: Error: "lfuse" memory not accessible using FLIP
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
avrdude done.  Thank you.
Now, I'm very confused. If I want to simply get a memory dump, I would've that the fact that the "Reading" loading bar reached 100% means that the memory was read, no?
I'm also not sure what the fuses mean. Am I using the wrong programmer? I'm using flip1, as you can see in the command.
Any help is much appreciated, thanks!
(If the circuit schematic is relevant, it can be found in my previous question, to which I linked at the top of this one.)
  • \$\begingroup\$ The error message indicates that the configuration fuses cannot be accessed by this method. That will be a problem if they are not already set in the states you require. It does appear that the flash memory can be read - have you examined the output file and determined if it is within range of expectation? If you write a program and read it back, does the readback contain the same information written (note that hex files can and typically do differ even when representing the same data unless they are created by the same tool) \$\endgroup\$ Mar 1, 2019 at 16:46
  • \$\begingroup\$ Typically fuses can only be changed by an external programmer such as an ISP adapter (something you can temporarily make by loading software onto another similar device, Arduino, etc...) \$\endgroup\$ Mar 1, 2019 at 16:48
  • \$\begingroup\$ What exactly are fuses? I assume they don't mean the component which breaks with too much current? \$\endgroup\$ Mar 1, 2019 at 16:50
  • \$\begingroup\$ That's a subject it would be worthwhile for your to do some searching and reading on - ie "atmega fuses" should be your search term. \$\endgroup\$ Mar 1, 2019 at 17:00
  • \$\begingroup\$ @ChrisStratton Hmm.. I think I have a brief understanding of them now. Any idea what's wrong with my fuses though? What do I have to change? \$\endgroup\$ Mar 1, 2019 at 17:07
@JacobGarby I think referring to "27.5 Entering the Boot Loader Program" in datasheet would give you a clear idea about Fuses which is controlled in firmware. You should Program the Boot Reset Fuse in order to reset from bootloader. Boot Reset Fuse
These parts are shipped with Pre Programmed USB Bootloader
