I know the answer is AC + ~AB, but how?
I have tried:
B(~A+C) + AC and stop.
Also, I have tried:
AC + BC + ~AB and have stopped.
There seems nowhere to go in either case.
  • 4
    \$\begingroup\$ Show what you've tried and be explicit with where you are confused. Help us to help you. \$\endgroup\$
    – Bort
    Mar 1, 2019 at 18:37
I will not give you the full solution, but the required non-trivial sidestep. You have got this far:
C(A + B) + A'B = AC + BC + A'B =
Now here is the sidestep. We know that (A+A') is 1, so we can do:
 = AC + (A + A')BC + A'B
From here you will need to expand it and use the "OR absorption law" twice.
  • \$\begingroup\$ @AlanKazemian (Be sure and hit the check mark so you can close the question) \$\endgroup\$
    – user103380
    Mar 1, 2019 at 19:11
  • \$\begingroup\$ @Eugene Sh. Expanding the brackets was an obvious step but your "sidestep" was one that I had not considered. Very useful and I will bear this in mind for future tasks. A Karnaugh Map would also have provided a easy solution to the problem. \$\endgroup\$
    – Pzy
    Mar 1, 2019 at 21:00
