-5
I see syntax quit similar to this very frequently:
4'd0
Sometimes it is associated with an assign statement:
assign S0 = 2'b00;
I tried searching online however I could not find any sources.
    \$\begingroup\$ It is very hard for me to believe that the answer to this question was at all difficult to locate online. \$\endgroup\$ – Elliot Alderson Mar 2 '19 at 2:03
    \$\begingroup\$ Actually, it would be hard to search for if you didn't know what is was called. But any basic tutorial would show this. \$\endgroup\$ – dave_59 Mar 2 '19 at 5:36
This is simply how a value is given. 4'd0 is a 4-bit value, given in base 10 (decimal), with value 0. 2'b00 is a 2-bit value, given in binary, with value 0.
The following four values are equivalent and all equal to fifteen:
4'b1111 (binary)
4'd15 (decimal)
4'hf (hexadecimal)
4'o17 (octal)
  • \$\begingroup\$ That makes sooo much sense! But when do you normally use them? For example, if I wanted to assign a [4:0] bit array to the value of 1101 would I do something similar to S0 [4:0] = 4'b1101? Where each bit S[0] - S[3] would contain each binary number 1101 respectively? \$\endgroup\$ – Code4life Mar 2 '19 at 9:58
  • \$\begingroup\$ @Code4life Yes, precisely. \$\endgroup\$ – Reinstate Monica - ζ-- Mar 2 '19 at 16:20
These are integer literal constants defined in section 5.7.1 of the IEEE 1800-2017 LRM. Anyone using Verilog/SystemVerilog should have a free copy available at https://ieeexplore.ieee.org/browse/standards/get-program/page/series?id=80
