Say I don't have a ideal transmission line i.e resistance/length!=0. Also E-Field exists between the two conductor lines. How then current flows through the line? There is no E-Field along the line right?
Sure there's an E-field along the line. When you apply a voltage at one end, the other end is still at 0V — how is that not a lengthwise voltage difference?
  • \$\begingroup\$ Yes there should be an E-field but in many places I saw they are only considering E-field existing between the conductors \$\endgroup\$ Mar 2 '19 at 15:02
    \$\begingroup\$ If you want me to address that specifically, you're going to have to show us the reference. \$\endgroup\$
    – Dave Tweed
    Mar 2 '19 at 15:10
-1
The following answer is related to RF communications transmission lines. In power transmission lines the answer would be a little different than the following.
Almost all RF transmission lines consists of two conductors. The purpose is to transmit a relative high frequency signal (electromagnetic wave) through the line by changing the voltage across the line following any AC waveform (mostly sine but triangular, square is possible). The change of voltage polarity from peak positive to zero and then to peak negative between the 2 conductors creates a permanent time changing electric field between these 2 conductors, which moves through the dielectric between them at a speed near the light speed (but never equal unless the dielectric is air). The speed is not of any concern since in our human perception it is "instantaneous". Then, what about the electric current? Since there is a change of voltage between the two conductors at any specific point, there must be also a change of the amount of charge that produce it. This change in electric charge at any point along the transmission line is produced by an electric current, back and forth, that exists because of the time changing voltage applied to the transmission line. So a back and forth electric current exist in a transmission line when an AC voltage is applied at any end of this line. Note that the transmitted information is received at the end of the transmission line by measuring the change in voltage at that end. By the way, a change in intensity and polarity of an electromagnetic field that hit a conductor also creates this change in current and, as a consequence, a change in voltage at the end of this conductor. This is the behavior of an receiver antenna.....
  • \$\begingroup\$ Can you put some paragraphs in. It's a wall of text at the moment. \$\endgroup\$
    – Chu
    Mar 2 '19 at 15:57
  • \$\begingroup\$ I'm not sure it would help. This is just a lot of hand-waving that doesn't really explain anything. \$\endgroup\$
    – Dave Tweed
    Mar 2 '19 at 17:07
-1
There is a voltage difference!
Ok, a normal transmission line.
Ok, that's still the case with any normal transmission line. But why should it matter?
Why? Of course, there is an electric field along the line, and a current flows - as proven by usage of almost any hair-dryer or washing machine.
In fact, there wouldn't be an electric field along the line, if the transmission line was ideal.
    \$\begingroup\$ The last statement is simply false. \$\endgroup\$
    – Dave Tweed
    Mar 2 '19 at 17:05
  • \$\begingroup\$ @DaveTweed: Explain why, please! If the transmission line was ideal in the sense of having zero resistance, the smallest electric field would necessarily imply an infinite current. \$\endgroup\$ Mar 3 '19 at 0:15
  • \$\begingroup\$ Not at all. Even a superconducting transmission line has the characteristic inductive and capacitive effects. The current doesn't become instantly infinite! It takes time to build up, during which, there's a lengthwise E field imposed across the self-inductance of the line. \$\endgroup\$
    – Dave Tweed
    Mar 3 '19 at 12:16
  • \$\begingroup\$ @DaveTweed: Well, I have to agree. There are longitudinal electric fields even in superconductors, if you look at the propagation of waves with longitudinal e-fields, but the (temporal and spatial) average electric field strength along the line does still decrease towards zero with increasing conductivity of the wire. \$\endgroup\$ Mar 3 '19 at 22:44
