What is the desired ripple frequency for buck converters connected to computers, networking device as power supplies?
Can we judge the quality of power supply from ripple frequency? (buck converter or SMPS adapters) What does the ripple frequency number mean?
Also can we measure ripple using multimeter?
    \$\begingroup\$ Which question are you asking? \$\endgroup\$ – Solar Mike Mar 3 '19 at 8:32
  • \$\begingroup\$ All of it! but I think all are kind of related in asking what is the relationship between ripple and quality of power supply. \$\endgroup\$ – NS Gopikrishnan Mar 3 '19 at 9:48
  • \$\begingroup\$ See electronics.stackexchange.com/help/how-to-ask \$\endgroup\$ – Solar Mike Mar 3 '19 at 10:05
Ideally you don't want and don't get any ripple so the desired ripple frequency would be zero. In practice you minimise the ripple so that it does not affect the circuits being powered. Frequency is unlikely to matter in your use cases. In very noise-sensitive analog applications; it might.
Figure 1. Buck converter circuit diagram. Source: Wikipedia's buck converter.
Ripple frequency just tells you the frequency the converter is switching at. In general, the higher the switching frequency the smaller the inductor can be because it has to store less energy per cycle as the cycles are shorter. (This is why switched mode power supplies are so much smaller and lighter than mains frequency transformers.) At some point high frequency losses will become apparent so, as with all designs, the sweet spot is the best compromise between performance, cost, size, efficiency, weight, etc.
Generally not. If you have a multimeter with a sensitive frequency meter you might but I suspect that if you can then you have a high ripple and the PSU might be a poor one.
  • \$\begingroup\$ Is a smaller switching frequency number better compared to the higher ripple frequency? \$\endgroup\$ – NS Gopikrishnan Mar 3 '19 at 9:47
  • \$\begingroup\$ What do you mean by "switching frequency number". Do you simply mean "switching frequency"? \$\endgroup\$ – Transistor Mar 3 '19 at 9:51
  • \$\begingroup\$ @NSGopikrishnan in case you just mean "lower switching frequency": No, that is generally not better, because a) the inductor needs to be larger for the same current, and b) it's harder to filter out lower frequencies if you want DC – which is the lowest of all frequencies. \$\endgroup\$ – Marcus Müller Mar 3 '19 at 10:12
  • \$\begingroup\$ @Transistor mind if I add a "…in your application" to "frequency is unlikely to matter"? I mean, when designing an analog signal processing device, you'd typically take care to either put switching noise far away from the signal of interest in spectrum, or use spread-spectrum switch controllers; but that part of the info might confuse OP. \$\endgroup\$ – Marcus Müller Mar 3 '19 at 10:14
  • \$\begingroup\$ @Marcus: Work away ... \$\endgroup\$ – Transistor Mar 3 '19 at 10:16
