I'm trying to use the __delay_ms() function to make an LED blink on the PIC16F77A.
The reason I think it stalls on the __delay_ms() function is because whatever I set RB0 to before the delay function always works, while anything after it doesn't (for any value I pass in).
I'm using a PICKit3 and MPLAB X to program my board. I have a 10k pullup on MCLR and a 16MHz oscillator with two 22pF capacitors in parallel on pins 13 and 14 of the PIC, and RB3/PGM wired to ground (basically the same setup as in this tutorial). I've also tried this with a 20MHz oscillator (with 22pF and 33pF capacitors, as specified in the datasheet).
#include <xc.h>
// BEGIN CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF        // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
//END CONFIG
#define _XTAL_FREQ 16000000
void main()
    TRISB0 = 0; //RB0 as Output PIN
    while(1) {
        RB0 = 0;
        __delay_ms(1000);
        RB0 = 1;
        __delay_ms(1000);
  • \$\begingroup\$ The code above leaves the LED off. If instead I put RB0 = 1 before RB0 = 0, it leaves the LED on. \$\endgroup\$ – Chris S Mar 4 '19 at 19:26
i.e. The code above should ultimately turn the LED on, but it stays off. –
It doesn't. the PIC probably reset after reaching the end and re-enter the main method. If you want to stop after the last line, add a while (1); at the end.
With 2 times 10ms delay, you would hardly see a LED light up, especially you are not in a loop.
First, put your code in a loop like so so that it keeps executing and only select the pin you want as output:
void main()
    TRISB0bits.TRISB0 = 0; //RB0 as Output PIN
while (1) {
    RB0 = 0;
    __delay_ms(10);
    RB0 = 1;
    __delay_ms(10);
Then you state:
I have a 10k pulldown on MCLR
You need a 10k pullup, not pulldown.
For the oscillator, try first to use the internal oscillator to make sure you don't have issues in this regard.
  • \$\begingroup\$ Thanks for your reply. I misspoke when I said I have a 10k pulldown; it's connected as a pullup. I think my example was also somewhat poor. If I have something like this, the LED stays on, but if I swap the order of the LED toggle (i.e. instead have RB0 = 0, then RB0 = 1), it stays off. while(1) { RB0 = 1; __delay_ms(1000); RB0 = 0; __delay_ms(1000); } \$\endgroup\$ – Chris S Mar 4 '19 at 19:13
