I have this BMS module for 3 cell lithium ion battery protection. as this guy explain the BMS modules can charge the batteries but not ideally, so we need a separate charger module to fully charge the batteries.
TP4056 is what i'm gonna use as a charger module.
TP4056 is a one cell module and provides 4.2V output, while each cell connected to different parts of BMS module which requires different voltages from batteries in order to monitor over-charge/discharge.
Does TP4056 module conflict with the BMS?
