I am continuously sending a substantial amount of data between the STM32L432 and a FPGA using SPI in full-duplex mode. I decided to implement DMA on the L432 in order to increase the transfer rate between the two devices.
When I start the communication between the two, the L432 locks up and remains unresponsive. I have a LED in the interrupt service routines for testing purposes which is to be toggled when the ISR is being serviced but the program does not reach that point. I have been trying to solve this problem for days now and have no idea what is causing this to happen.
This is how I set up the SPI and the DMA:
#include "mbed.h"
#include "DMA_SPI.h"
int16_t data_to_transmit[10];
int16_t received_data[10];
DigitalOut myled(LED1);
void SPI_DMA_init() {
    myled = 1;        //toggle LED on
    //Deinitialise
    SPI_DMA_SLAVE_deinit();
    deinitDMA();
    //Initialise
    initDMA();
    SPI_DMA_SLAVE_init();
    //Start DMA communication
    startCommunication();
/* Starting DMA communication according to STM32L432 Reference Manual p1317-p1318*/
void startCommunication() {
    SET_SPI1_CR2_RXDMAEN_BIT();                                                 //Enable RX DMA buffer
    DMA1_CH3_ENABLE();                                                          //Enable DMA channel 3
    DMA1_CH2_ENABLE();                                                          //Enable DMA channel 2
    SET_SPI1_CR2_TXDMAEN_BIT();                                                 //Enable TX DMA buffer
    SPI1_ENABLE();                                                              //SPI module enabled
//====================================================DEINITIALISE=========================================================================
void SPI_DMA_SLAVE_deinit() {
    //Disable the clocks
    RCC->AHB2ENR &= ~(RCC_AHB2ENR_GPIOAEN);
    RCC->APB2ENR &=  ~(RCC_APB2ENR_SPI1EN);
    //Clear pin settings
    GPIOA->MODER&=~((3u<<(2*CS_slave)));                                         //clear GPIOA pin mode (in input mode when reset)
    GPIOA->MODER&=~(                                                             //clear GPIOB
            (3u<<(2*SCK_slave))
            |(3u<<(2*MISO_slave))
            |(3u<<(2*MOSI_slave))
            |0x03
    GPIOA->AFR[0]&=~(                                                            //clear alternate function selector bits
            (0x0f<<(4*SCK_slave))
            |(0x0f<<(4*MISO_slave))
            |(15u<<(4*MOSI_slave))
    //Clear SPI bits
    SPI1_DISABLE();
    CLEAR_SPI1_CR1_MSTR_BIT();
    CLEAR_SPI1_CR1_BR_BITS();
    CLEAR_SPI1_CR1_SSM_BIT();
    CLEAR_SPI1_CR1_SSI_BIT();
    CLEAR_SPI1_CR1_CPOL_BIT();
    CLEAR_SPI1_CR1_CPHA_BIT();
    CLEAR_SPI1_CR2_DS_BITS();
    CLEAR_SPI1_CR2_RXDMAEN_BIT();
    CLEAR_SPI1_CR2_TXDMAEN_BIT();
    CLEAR_SPI1_CR2_RXEIE_BIT();
    CLEAR_SPI1_CR2_TXEIE_BIT();
void deinitDMA() {
    RCC->AHB1ENR &= ~(RCC_AHB1ENR_DMA1EN);                                      //Disable the DMA1 clock
    //Disable channels
    DMA1_CH2_DISABLE();
    DMA1_CH3_DISABLE();
    CLEAR_DMA1_SPI1RX_CSELR_BITS();                                             //deselect SPI1_Rx on DMA1 Channel 2
    CLEAR_DMA1_SPI1TX_CSELR_BITS();                                             //deselect SPI1_Tx on DMA1 Channel 3
//-----------------------------------------------Receive-----------------------------------------------------
   //Clear configuration bits
   CLEAR_DMA1_CH2_CCR_DIR_BIT();
   CLEAR_DMA1_CH2_CCR_PSIZE_BITS();
   CLEAR_DMA1_CH2_CCR_MSIZE_BITS();
   CLEAR_DMA1_CH2_CCR_MINC_BIT();
   CLEAR_DMA1_CH2_CCR_PINC_BIT();
   CLEAR_DMA1_CH2_CCR_TCIE_BIT();
   CLEAR_DMA1_CH2_CCR_CIRC_BIT();
   CLEAR_DMA1_CH2_CCR_MEM2MEM_BIT();
   CLEAR_DMA1_CH2_CCR_PL_BITS();
   CLEAR_DMA1_CH2_CCR_TEIE_BIT();
   CLEAR_DMA1_CH2_CNDTR_BITS();
   CLEAR_DMA1_CH2_CPAR_BITS();
   CLEAR_DMA1_CH2_CMAR_BITS();
//-----------------------------------------------Transmission------------------------------------------------
    CLEAR_DMA1_CH3_CCR_DIR_BIT();
    CLEAR_DMA1_CH3_CCR_PSIZE_BITS();
    CLEAR_DMA1_CH3_CCR_MSIZE_BITS();
    CLEAR_DMA1_CH3_CCR_MINC_BIT();
    CLEAR_DMA1_CH3_CCR_PINC_BIT();
    CLEAR_DMA1_CH3_CCR_TCIE_BIT();
    CLEAR_DMA1_CH3_CCR_CIRC_BIT();
    CLEAR_DMA1_CH3_CCR_MEM2MEM_BIT();
    CLEAR_DMA1_CH3_CCR_PL_BITS();
    CLEAR_DMA1_CH3_CCR_TEIE_BIT();
    CLEAR_DMA1_CH3_CNDTR_BITS();
    CLEAR_DMA1_CH3_CPAR_BITS();
    CLEAR_DMA1_CH3_CMAR_BITS();
    NVIC->ISER[0]&= ~(1u<<12);                                                   //Disable DMA1 channel 2 interrupt
    NVIC->ISER[0]&= ~(1u<<13);                                                   //Disable DMA1 channel 3 interrupt
void SPI_DMA_SLAVE_init() {
    RCC->AHB2ENR|= (RCC_AHB2ENR_GPIOAEN);                                       //GPIO A clock enable
    RCC->APB2ENR|=RCC_APB2ENR_SPI1EN;                                           //Enable SPI1 Clock
   //SET SCK, MISO, MOSI and CS pins
    GPIOA->MODER|=(
            (2u<<(2*SCK_slave))
            |(2u<<(2*MISO_slave))
            |(2u<<(2*MOSI_slave))
            |0x01
    //SET pins to function as SPI pins
    GPIOA->AFR[0]|=(
            (5u<<(4*SCK_slave))
            |(5u<<(4*MISO_slave))
            |(5u<<(4*MOSI_slave))
    SET_SPI1_CR1_BR_BITS();                                                     //baud rate bits set 1/16 giving 1MHz SCK frequency
    SET_SPI1_CR1_CPOL_BIT();                                                    //CPOL = 1
    SET_SPI1_CR1_CPHA_BIT();                                                    //CPHA = 1
    SET_SPI1_CR2_DS_BITS();                                                     //Data Size = 16 bits
    SET_SPI1_CR2_RXDMAEN_BIT();                                                 //Rx buffer DMA enable
    SET_SPI1_CR2_TXDMAEN_BIT();                                                 //Tx buffer DMA enable
void initDMA() {
    RCC->AHB1ENR|= (RCC_AHB1ENR_DMA1EN);                                        //Enable the DMA1 clock
    DMA1_CH2_DISABLE();                                                         //Disable DMA channel 2
    DMA1_CH3_DISABLE();                                                         //Disable DMA channel 3
    SET_DMA1_SPI1RX_CSELR_BITS();                                               //Select SPI1_Rx on DMA1 Channel 2
    SET_DMA1_SPI1TX_CSELR_BITS();                                               //Select SPI1_Tx on DMA1 Channel 3
   CLEAR_DMA1_CH2_CCR_DIR_BIT();                                                //Peripheral->Memory
   SET_DMA1_CH2_CCR_PSIZE_BITS();                                               //16 bits
   SET_DMA1_CH2_CCR_MSIZE_BITS();                                               //16 bits
   SET_DMA1_CH2_CCR_MINC_BIT();                                                 //Memory increment mode
   SET_DMA1_CH2_CCR_PINC_BIT();                                                 //Peripheral increment mode
   SET_DMA1_CH2_CCR_TCIE_BIT();                                                 //Transfer complete interrupt enable
   SET_DMA1_CH2_CCR_CIRC_BIT();                                                 //Circular Buffer mode
   SET_DMA1_CH2_CCR_PL_BITS();                                                  //Priority Level = Highest
    DMA1_Channel2->CNDTR = 10;                                                  //number of data to transfer from the peripheral to memory.
    DMA1_Channel2->CPAR = (int32_t)&SPI1->DR;                                   //Source Adddress = SPI data register
    DMA1_Channel2->CMAR = (int32_t)received_data;                               //Destination address = received_data array
   SET_DMA1_CH3_CCR_DIR_BIT();                                                  //Memory->Peripheral
   SET_DMA1_CH3_CCR_PSIZE_BITS();                                               //16 bits
   SET_DMA1_CH3_CCR_MSIZE_BITS();                                               //16 bits
   SET_DMA1_CH3_CCR_MINC_BIT();                                                 //Memory increment mode
   SET_DMA1_CH3_CCR_PINC_BIT();                                                 //Peripheral increment mode
   SET_DMA1_CH3_CCR_TCIE_BIT();                                                 //Transfer complete interrupt enable
   SET_DMA1_CH3_CCR_CIRC_BIT();                                                 //Circular Buffer mode
   SET_DMA1_CH3_CCR_PL_BITS();                                                  //Priority Level = Highest
    DMA1_Channel3->CNDTR = 10;                                                  //number of data to transfer from memory to the peripheral
    DMA1_Channel3->CPAR = (int32_t)&SPI1->DR;                                   //Destination address = SPI data register
    DMA1_Channel3->CMAR = (int32_t)data_to_transmit;                            //Source address = data_to_transmit
    NVIC->ISER[0]|= (1u<<12);                                                   //Enable DMA1 channel 2 interrupt
    NVIC->ISER[0]|= (1u<<13);                                                   //Enable DMA1 channel 3 interrupt
    NVIC_EnableIRQ(DMA1_Channel2_IRQn);
    NVIC_EnableIRQ(DMA1_Channel3_IRQn);
//Interrupt Handler for DMA1 Channel 2
void DMA1_Channel2_IRQHandler(void) {
     myled = 0;        //Toggle LED off
     CLEAR_DMA1_CH2_IFCR_GFLAG();                                               //Clear Global Interrupt flag
//Interrupt Handler for DMA1 Channel 3
void DMA1_Channel3_IRQHandler(void) {
     myled = 0;
     CLEAR_DMA1_CH3_IFCR_GFLAG();                                               //Clear Global Interrupt flag
Is there anything that I am missing?
    \$\begingroup\$ Would suggest you move from LEDs to toggling GPIOs and get that and the SPI itself on a cheap USB based logic analyzer. Then run it all with the debugger connected and a breakpoint in the hardfault hander, and if still inconclusive stop it with the debugger and see where it is... \$\endgroup\$ – Chris Stratton Mar 4 at 22:32
  • \$\begingroup\$ Also, really look at the behind the scenes code... there is a some eye opening stuff deep in the internals of mbed that may prove quite a bit different than what you might imagine from the outside. \$\endgroup\$ – Chris Stratton Mar 4 at 22:33
  • \$\begingroup\$ Not sure if only problem, but at your deinit functions you disable clock first and then you try clear settings. \$\endgroup\$ – Rokta Mar 5 at 10:10
  • \$\begingroup\$ @Rokta You are correct, I have changed my code to disable the clock after I clear the bits. \$\endgroup\$ – Zed Mar 8 at 1:03
I found the solution to this problem. Because I am using a C++, I needed to use extern "C" on the interrupt handlers according to this post. My interrupt handlers are now written like this:
extern "C" void DMA1_Channel2_IRQHandler(void) {
