My problem is I need to have an amplifier circuit design - schematic + components BOM with specific model information that is able to provide a dimmable output signal (Vout) 0.2-10V <0.8A for a set of 8x LED drivers using Raspberry Pi PWM GPIO pin which is able to provide input signal (VG) of 0-3.3V <16 mA.
My understanding is that this can be achieved using MOSFET amplifier circuit. I hired an LED vendor to design such a circuit and when he tested in the workshop he was unable to lower the Vout to <1 V, and consequently his circuit was unable to switch off the LED lights. The MOSFET he selected was a D882 P33. The LED lights need to have a low signal of 0-0.25A in order to turn OFF. A negative signal will turn the lights back ON again.
I did some workshop testing using a circuit similar to the one below obtained from an online course from ECE UCSB, and reproduced the same problem. I replaced the RBPI using a universal AC adapter 3V 500mA to not damage the RBPI during testing.
During my testing there were four problems I encountered
1) I was also unsuccessful to lower the Vout to <1A using two MOSFET models BF506 and 2N3906. I believe that this requires a MOSFET with RDSON of <0.15Ohms and I couldnt find this value on the datasheet specifications for these models.
2) I was unsuccessful to establish a minimum drain voltage using R1, R2 resistors and was confused by the capacitor in the VG front end of the circuit. When I connected a 100k Ohm resistor for R1 and a tiny resistance <100Ohms for R2 and the VCC connected to the VG front-end circuit, I was unable to control the voltage VG and the voltage would shoot up to >4V. I then removed the R1, R2 and the VCC connections and was then able to control the voltage.
3) I was not able to use the circuit when the capacitor was connected. Again the voltage VG would shoot up to 3.3V and I could not adjust at all, so I removed the capacitor.
4) The behavior of the VG and Vout was inverted from what was expected. When I provided a 0.9V signal VG, I received a 2.05V Vout, and for a 3.3V VG --> 4.32V out. This is opposite to what was expected which is for the higher VG voltage to produce a low output signal Vout.
I'm adding a photo of the LED drivers. The vendor provided two types of models in the system. I realize in the original problem description I described for a single LED driver, but actually the system is 8x drivers connected in parallel. Of the 8x drivers there are at least 2x different models, I have not opened to inspect for the other 6x.
enter image description here enter image description here enter image description here
  • \$\begingroup\$ which LED dimmerr? \$\endgroup\$ Commented Mar 5, 2019 at 7:40
  • \$\begingroup\$ Why do you seem to want an analog solution and not a PWM one? \$\endgroup\$ Commented Mar 5, 2019 at 18:25
  • \$\begingroup\$ (Re:Chris) I am looking for a soution that works with digital PWM GPIO input signal from RBPI, if the way I draw looks like its analog then that would be my mistake. I am learning as I go along. \$\endgroup\$ Commented Mar 6, 2019 at 8:38
Rather than explain or fix the circuit you show which does not have a chance of working I will show what will work.
Specs:
0 to 3.3V source ( low Z) must be amplified to 0 to 10 out.
Load Impedance: assumed high Z.
Easiest solution is a rail to rail in & out (RRIO) Op Amp (OA) with a 10V supply. (LDO)
Gain= 10/3.3=3.03 ( round up )
Resistor range: 100k preferred.
Here is a discrete solution from 0.1V to ~10V
  • \$\begingroup\$ Thanks for the response! I have a few follow-up questions to understand how to interpret the sketch. Just now I opened in CircuitLab and tried to understand by using the DC Sweep but was unsuccessful, all of the voltages showed negative values. Questions \$\endgroup\$ Commented Mar 5, 2019 at 6:08
  • \$\begingroup\$ CLab is lame, I never use it tinyurl.com/y5bwrbah \$\endgroup\$ Commented Mar 5, 2019 at 6:13
  • \$\begingroup\$ Thanks for the response! I have a few follow-up questions to understand how to interpret the sketch. I haven't yet researched OpAmp circuits so I need some time to study. Just now I opened in CircuitLab and tried to understand by using the DC Sweep but was unsuccessful, all of the voltages showed negative values. Questions 1) could you label Vout 0-10V, and VCC source 12V? 2) What should the voltage be to the input to the JFET? The way I read it the source 0-3.3V is before the R1 100 kOhm resistance and the input to the U1 JFET is some tiny value, is that correct? \$\endgroup\$ Commented Mar 5, 2019 at 6:17
  • \$\begingroup\$ no. the circuit you show cannot work as a linear amp. \$\endgroup\$ Commented Mar 5, 2019 at 6:19
  • \$\begingroup\$ Thanks for the link to the simulator on falstad. I have a few more questions on the differences between the falstad and the Clab circuit. 1) the falstad circuit doesn't show the top part of U2, can I ignore that part? 2) whre is the RBPI signal ? before or after the 100k resistance? If the RBPI signal is the little line that is going from 0-3.3V then what is the 40HZ source supposed to represent? \$\endgroup\$ Commented Mar 5, 2019 at 6:25
