I'm getting an error in Verilog with an input parameter it's not recognized as a legal reg or a variable lvalue. I had the same problem with the output in the module however it was fixed by labeling it as a reg. It's the only error in my code and it occurs only at the input reset variable in the always block.
module lasersystem(input clk, input reset, output reg click
reg [1:0] next_state = 2'b00;
localparam off = 2'b00, start = 2'b01, on = 2'b10;
reg [32:0] counter;
always @ (clk)
begin
case (next_state)
off: if (clk == 0) begin
        next_state = off;
        reset = 1;
        counter = 32'd0;
        click = 0;
        end
      else if (clk == 1) begin
        next_state = start;
        reset = 1;
        counter = 32'd0;
        click = 0;
        end
start: if (clk == 1) begin
          reset = 0;
          click = 0;
          counter = 32'd0;
          next_state = on;
        end
         else begin
          next_state = on;
          reset = 0;
          counter = 32'd0;
          click = 0;
         end
on: if (clk == 1) begin
        reset = 0;
        click = 1;
        if (counter == 32'd249999999) begin
            next_state = off;
        end
        else if (counter != 32'd249999999)
            next_state = on;
    end
default: next_state = off;
endcase
end
always @ (posedge clk) begin
case (reset)
    1: if (next_state == off) while (counter > 32'd0 && counter <     32'd250000000) counter = counter - 32'd1;
    0: if (next_state == on) while (counter > 32'd0 && counter < 32'd250000000) counter = counter + 32'd1;
default: counter = 32'd0;
endcase
end
endmodule
Why does this happen?
    \$\begingroup\$ You've labelled reset as input but then you try and assign a value to it (reset = 1). That's what the error is flagging up. \$\endgroup\$
    – awjlogan
    Mar 5, 2019 at 22:21
If your state machine needs to set reset, then you need to specify it as an output reg reset of your module. Outputs default to nets unless you add a data type like reg. Then they are treated like variable that can be procedurally assigned from your `always1 block.
  • \$\begingroup\$ I have never considered the reset reg or wire as an ouput. Most of the time I see in class the reset is used as an input, but I'll configure the code later and see if that worked. \$\endgroup\$
    – user548010
    Mar 5, 2019 at 23:11
    \$\begingroup\$ @user548010, If it's not an output, then why is your code setting it to a specific value? (I'm mainly asking because maybe I haven't understood what the code is actually supposed to do) \$\endgroup\$
    – The Photon
    Mar 6, 2019 at 0:45
