I have a PCB that was poorly designed and there is a ground pad that is too close to a signal pad. As a result, the signal pad on the surface mount component will short to ground. I was looking to use some ink or other material to cover the ground pad. The pads are too small to fit Kapton tape. Are there any standard materials used to cover PCB SMT pads?
Solution: I ended up cutting the pad out of the board using a very small razor blade. Picture from under a microscope of the end product:
