I want to find the minimum resistance \$R_L\$ so as to maintain \$V_z\$(voltage of the zener corresponding to the minimum current \$I_{z_0}\$) across the same resistor \$R_L\$.
I have two ways of looking at this, one of them is wrong and I need your help to figure it out!
First method:
I take off the diode as the load and find thevenin voltage : $$V_{th}=\frac{R_L}{R_l+R_s}V_s$$
Since
\$V_{th}=V_{R_L}\$
I'll equate it with \$V_z\$ which gives :
\$\frac{R_L}{R_L+R_S}V_S=V_z\$
thus
\$R_L=\frac{R_S.V_z}{V_S-V_z}\$
Second method:
If \$R_L\$ is minimal then \$I_L\$ passing through it would be maximal and \$I_z\$ minimal (\$= I_{z_0}\$) thus we'd have :
$$I_S = I_L+I_{z_0} \Leftrightarrow \frac{V_S-V_z}{R_S}=\frac{V_z}{R_L}+I_{z_0}\Leftrightarrow R_L=\frac{R_S.V_Z}{V_S-V_Z-R_S.I_{z_0}}$$
(I'm skeptical concerning the implication \$I_L\$ maximal \$\Rightarrow\$ \$I_z\$ minimal, or in other words \$I_z = I_{z_0}\$)
  • \$\begingroup\$ Maybe you could rearange the text in more lines, so it would be better readable. For examle 1. and 2. ,...Altrough nice use of latex equations, so +1. A good staritng point would be \$V_{R_L}=V_Z\$ \$\endgroup\$ – Marko Buršič Mar 8 '19 at 10:00
  • \$\begingroup\$ Will do! That's what I did, look at "First". \$\endgroup\$ – Luyw Mar 8 '19 at 10:02
    \$\begingroup\$ +1 from me, this is a good example of how the 'I'm confused with this circuit' questions should be asked. OP explains what they are trying to so/understand/solve, then explains their thinking behind it, and shows how they attempted to tackle the problem. \$\endgroup\$ – MCG Mar 8 '19 at 10:07
A typical 300mW Zener uses a test current Izt=5mA with an incremental resistance Zzt and a threshold current, at 1/10 Izt or It @ 0.5mA which results in a knee resistance of Zzk approx. 10x Zzt.
The same is true for LEDs.
Make a Thevenin equivalent circuit for 5mA at a low power.
This gives the low rated resistance, Zzt and is important to include in the equation to solve for R1.
Now you can easily solve for R1
| improve this answer | |
\$ V_S = V_{R_S} + V_Z\$
\$ V_S = I_S\cdot R_S + V_Z\$
\$ I_S = I_Z + I_L\$
\$ V_S = (I_Z + I_L)\cdot R_S + V_Z\$
\$ I_L = \dfrac{V_Z}{R_L}\$
\$ V_S = (I_Z + \dfrac{V_Z}{R_L})\cdot R_S + V_Z\$
\$ R_S =\dfrac{V_S - V_Z}{I_Z + \dfrac{V_Z}{R_L}} \$
\$ R_S =\dfrac{V_S - V_Z}{I_{Z_0}+ \dfrac{V_Z}{R_{L_{min}}}} \$
EDIT: It's not what your asking for...wait a minute...
\$R_{L_{min}}=\dfrac{R_S\cdot V_Z}{V_S-V_Z-R_S\cdot I_{Z_0}}\$
I guess you got the same.
  • \$\begingroup\$ Yes for the second method, why doesn't the first work though? For me it seems logical. \$\endgroup\$ – Luyw Mar 8 '19 at 10:48
  • \$\begingroup\$ Hmm..I guess the thevenin voltage is not equal to Vz as long there is no minimal current Iz0 present. \$\endgroup\$ – Marko Buršič Mar 8 '19 at 11:02
