I'm working with STM32F and my application is checked automatically the connectivity of my ip_address.
Question:
How can I use the ping command in my programme to check the connectivity of my _Ip address?
  • \$\begingroup\$ It's unclear what you are asking or if that will work but ping is typically an ICMP echo request and in an MCU would be something you would probably have to specifically write or configure into the build, not just a command that sits there on the off chance it is needed. Look for ICMP support or example code in whatever IP stack you are using. This isn't really a question that fits here. \$\endgroup\$ – Chris Stratton Mar 9 at 13:11
