Would like to ask for help in the identification of 6-pin chip marked: W134H (it's not a clock signal generator)
I think it conditions very low voltage (5mv-200mv) analog voltage inputs for a chip marked AX4A which is an LMH6611 single supply rail-to-rail Amplifier.
Thank you for any help! (uploaded a better photo)
https://ibb.co/4TnsGJM
https://ibb.co/xLKkHqm
  • \$\begingroup\$ What function does this pcb serve? Input/outputs? Is it a mini jack input on the left side? \$\endgroup\$ – Linkyyy Mar 10 '19 at 9:02
  • \$\begingroup\$ Yes, it's a mini-audio jack. It has a two-channel audio input jack and the PCB measures the time difference between the two analog input signals. \$\endgroup\$ – TommyS Mar 10 '19 at 9:06
It appears to be a TVS diode array made by WURTH ELEKTRONIK
its position near an audio jack, makes it likely to be that.
| improve this answer | |
  • \$\begingroup\$ Thank you very much! It certainly makes sense. I partly traced the circuit back to the jack and both inputs of the stereo jack connect directly to the first two opposing pins. Most likely to protect the rest of the circuit from a surge, static, etc... \$\endgroup\$ – TommyS Mar 10 '19 at 16:53
