If I multiply a baseband signal \$A cos(C\omega t)\$ and a carrier signal \$B cos(D\omega t)\$, the result is \$\frac{AB}{2} [cos(C-D)\omega t+cos(C+D)\omega t]\$, which is a double sideband, suppressed carrier signal. My question is, how is the conversion gain defined in this situation? Would it be \$\frac{B}{2}\$ since the amplitude of each sideband is \$\frac{AB}{2}\$, or would it be \$B\$ since the total energy is spread among the two sidebands?
You have to define what you mean by 'conversion gain'. Once you've done that, the question resolves itself.
Usually, when buying balanced mixers from a catalogue, the manufacturer specifies conversion gain as 'wanted sideband power' / 'input power', which results in a figure of -6dB for 'ideal' mixers. It's constant because in an RF mixer, the LO power is constant. But that's a physical system.
If you want to define derived terms from a mathematical formula, then the definition will yield whatever you put into it.
