11
I'm using a USB-UART IC with an MCU, which is powered from a battery.
The USB-UART IC is powered from USB connector, not from the battery, so that I don't need to open up a console every time when the switch goes off and on.
edit: I didn't draw it on the figure but the IC has an internal 3.3V regulator and every VDD is on the 3.3V level when the switch is on.
Now I'm worried about when the USB is plugged and the switch is still off.
The MCU document says that every input pin's maximum rating is VDD + 0.3, which would be 0.3 V when the MCU is not powered.
If the TX/RX pair on the USB-UART side goes high, will it destroy the pins on the MCU side?
If so, What do I need between the TX/RX pairs?
  • \$\begingroup\$ @Toor What does "tbh" mean? \$\endgroup\$ Mar 11, 2019 at 19:42
    \$\begingroup\$ It'll probably be okay.The gates can should be able to tolerate up to their maximum operating voltage anyways since they need to be able to do that to function at the top end of their supply voltage range. The Vdd+0.3 is in reference to the ESD clamp diodes in the MCU, but if the MCU is unpowered, those diodes don't have a rail to clamp to. If a 5V capable MCU was being powered off 3V and you applied 5V to an I/O, those diodes would try and clamp to the 3.3V rail, but that doesn't mean it would blow without them at 5V. You can use series resistors to limit the current through said diodes. \$\endgroup\$
    – DKNguyen
    Mar 11, 2019 at 19:44
    \$\begingroup\$ @ElliotAlderson "tbh" is a common internet-ism for "to be honest". \$\endgroup\$
    – Hearth
    Mar 11, 2019 at 19:45
  • 7
    \$\begingroup\$ @Toor The diodes will create a power rail; see youtube.com/watch?v=2yFh7Vv0Paw. \$\endgroup\$
    – CL.
    Mar 11, 2019 at 19:57
  • 5
    \$\begingroup\$ This can indeed be an issue - not only the theoretical risk of damage but there are parts that won't do a clean power on reset if they were previously "sorta" powered by I/Os before real power was applied. If you find the board power net getting pulled up to .5v - .6v when "off" you may be in trouble territory. \$\endgroup\$ Mar 11, 2019 at 20:19
5 Answers 5
15
It depends on the MCU, but in most cases it'll power up the MCU, and possibly the rest of the board through the MCU. The MCU will try to run, and do odd things. Your board will do odder things. If your board draws enough current, it'll damage that pin on the MCU.
You need to arrange for the UART signal to stay at 0V when the MCU is off. If the UART chip (or UART) that you are using doesn't have an enable pin (the USB UART chips that I've worked with can be configured for exactly the case you're describing), then AND the UART outputs with the microprocessor's VCC.
  • \$\begingroup\$ Can you add an example for a USB UART chip that has an enable pin? Does the popular FTDI USB UART has such a feature? I've looked at an FTDI datasheet but couldn't find anything about such a feature. But perhaps they are using different terminology. \$\endgroup\$ May 21 at 0:07
    \$\begingroup\$ Now I'm looking through data sheets and not finding it! I'm not sure what two-year-ago me was thinking, but it's still dead easy to use an AND gate on the RX pin. \$\endgroup\$
    – TimWescott
    May 21 at 17:05
  • \$\begingroup\$ Thanks for the update - it seems that it isn't sufficient to just AND-gate the UART-TX pin of the MCU with its VCC. I connected a cheap FTDI USB device like this: just GND, DTR and MCU UART RX connected (USB side of the FTDI device not connected). With that the LED of the FTDI USB device doesn't power up anymore, but I measure that the power consumption of the MCU increases by ~ 34 µA. When I disconnect the UART the power consumption drops to 14 µA. The MCU under test (ATmega328p) is in power-down sleep mode. \$\endgroup\$ May 26 at 18:55
The solution might be as simple as an NMOS between the TX pin of the USB-UART (drain) and the RX pin of the MCU (source), with the gate connected to the MCU VDD.
This will mean that the USB-UART will only be able to drive up to 3.3 V minus the threshold voltage of the transistor. You'll have to check whether this is still enough to satisfy the V_IH of your MCU.
I'm skeptical of solutions that involve a logic gate powered (indirectly) by VBUS. As long as the logic gate drives the MCU input high, the MCU VCC may not drop far enough to switch off the TX driver. With the NMOS solution, the TX pin can only be driven to a lower voltage than VCC, making this sort of feedback impossible.
By the way, you should also consider the reverse direction: If the MCU is powered, but the USB-UART is not, you'll want to make sure that you don't accidentally provide some power to the USB-UART, draining your battery faster than you expect. A software-only solution should suffice for this.
I have a completely different solution, which, however, depends on which USB chip you use.
Some of them have different VBUS and VCCIO. In this case, you might be able to power the IO part of that chip together with the uC.
    \$\begingroup\$ This is a a good idea but be sure to read the USB transceiver's datasheet carefully. Some ICs will latch-up of have other failures if a power supply is not applied. The Absloute Maximum Ratings section near the beginning on the datasheet should cover this. \$\endgroup\$
    – jherbold
    Mar 13, 2019 at 20:28
Easy solution is to put some resistors between the I/O pins. This will limit the current flow into the pins so the transceiver cannot power the uC. The resistor value is a balance between limiting the bandwidth between the chips and limiting the current.
Logic buffers powered by the USB but with outputs enabled by the uC. This does the same as the transceiver output enable of the other answer.
Is there an advantage to having the uC off when it's connected to the computer? If not you can power the uC from the 5 V USB power. Ways to do this are:
  1. An SPDT switch that selects USB power when battery power is off. Replaces the SPST switch in your circuit diagram.
  2. A diode, diodes, an ideal diode integrated circuit, or MOSFETs controlled by the uC to select USB power when available. Now you need to consider what happens when the battery switch is closed and the USB is connected. Uncontrolled battery changing is rarely a good thing.
  • 7
    \$\begingroup\$ You might think so - but resistors alone do not actually work. Even a large series resistor on the UART receive line won't do it (though it may prevent damage). The problem is that that until you exceed some very low threshold voltages, nothing really draws current, and even then not much without a clock. So even with series resistors, the board power rail can be pulled up to the point where things just begin to have inappropriate state, at which point power on reset is no longer reliable. \$\endgroup\$ Mar 12, 2019 at 3:29
  • \$\begingroup\$ Agreed. Thank you for providing more detail to my answer. I was hoping to provide a quick prototype solution and should have said that. It is not an fool proof solution and will only work if the uC start-up current is high enough to create enough voltage drop on the resistors to keep voltage at the uC low enough that it doesn't get out of brown out. \$\endgroup\$
    – jherbold
    Mar 13, 2019 at 20:33
Have you considered if a couple tri-state buffers would be a good solution? You could tie the enable pin to your switch and then make sure the polarity from tx to rx is correct, which effectively gives you the protection you are asking for.
