We are iterating a device whose metal chassis is internally connected to an ESD guard ring that is connected to the PCB signal ground through a 0Ohm resistor in a single point close to the power connector (image A). It also has two USB connectors and one RJ45 connector with their chassis connected to this guard ring. Everything has worked very well with this device.
Now we have added five SMA connectors to this device and we are not sure how to connect the ground pins of these SMA connectors with the signal ground of the PCB.
Since the SMA connectors have a metal body, if we connect them directly to signal ground they will be grounding the metal chassis of the device.
Do we have to connect the body of the SMA connectors directly to signal ground, connect the chassis of the device directly to signal ground and not have the ESD guard ring? (image B).
  • \$\begingroup\$ ESD ingress and RF impedances depend on layout and tolerance of devices. The components involved have not been clearly stated yet nor the ground return paths and potential for ground shift.. Solutions may exist after the EMC system requirements are clear, on what you need to protect and effects on signal integrity. \$\endgroup\$ Commented Mar 12, 2019 at 20:03
    \$\begingroup\$ Is it important that the guard ring ground and signal ground be distinct? If so, you might be better served by a different type of connector. \$\endgroup\$
    – Hearth
    Commented Mar 12, 2019 at 20:04
    \$\begingroup\$ It isn't unheard-of to isolate the coax connector from the enclosure. One of my clients does that for the BNCs used for SDI video all the time. They use a plastic bushing on one side and a small circuit board on the other side that carries a bunch of SMD capacitors to make an AC connection to the enclosure. \$\endgroup\$
    – Dave Tweed
    Commented Mar 12, 2019 at 21:57
There is a choice here, and it depends on what you want most. If the signal of the SMA connector needs to be impedance controlled (like high frequency RF) then don't separate the planes. A way to tell if would be to ask yourself this question: Would cutting the shield (somewhere on the cable that goes to the SMA connector) and inserting an 0.1Ω resistor affect your signal (0.1Ω would probably be similar or worst case to the impedance between chassis and signal ground). If it would then don't tie the shield to the chassis, go to the PCB signal ground.
If the signal isn't affected by impedance, and ESD is the major concern then tie the SMA shield to the chassis ground.
Something noteworty:
PCB's can have two grounds, there are many boards that I've built that have a chassis ground solely for ESD events which I've attached shield's to. In some cases I've even used a fastener for the PCB chassis ground. If an ESD event hit's the shield, the current from ESD goes out down through the fastener and returns through the chassis. (away from sensitive electronics). If there are two grounds, make sure there is clearance between the two grounds on the PCB
