I try to design a analog PLL. I use a doubly balanced mixer as phase detector and a VCXO. The reference is a benchtop signal generator.
So I currently try to design the loop filter, and I struggled a bit when I wanted to estimate the bandwidth of my loop. As far as I remember, the transfer function of the VCXO is
\$ H(s) = \frac{K_{VCO}}{s} \$
and I try to use a loop filter as follows:
If I am correct, the transfer function of this device would be
\$ G(s) = - \frac{s\,C\,R_2 + 1}{s\,C\,R_1} \$
So the closed-loop transfer function would be
\$ CLTF(s) = \frac{ G(s) \cdot H(s) }{ G(s) \cdot H(s) + 1 } \$
which equals
\$ CLTF(s) = -K_{VCO} \cdot \frac{ s\,C\,R_2 + 1 }{s^2\,C\,R_1 - K_{VCO}\,s\,C\,R_2 - K_{VCO} } \$
however, I have the impression that this is unstable. So I have several questions.
- Am I wrong, and the loop is indeed stable? why?
- What is the bandwidth of a PLL with the above loop filter? Is it the frequency where my loop filter crosses 0 dB, or which frequency is it? I want a small loop bandwidth around 10Hz or so.
Edit: A third question arises: does the tuning slope of the VCO matter when I use an analog phase detector? At first glance I thought yes, but depending on the operating point, the analog phase detector can have both, positive and negative slope - so a VCO with any polarity can be used, is that true?
Edit #2: I add some more details according to Neil's answer. The circuit suggested is the following:
Its transfer function is:
\$ G(s) = - \cfrac{ \cfrac{1}{s\,C_2} + \cfrac{1}{ \cfrac{1}{R_2} + s\,C_1 } }{R_1} = \frac{ s\left( C_1 + C_2 \right) R_2 + 1}{s^2\,C_1\,C_2\,R_1\,R_2 + s\,C_2\,R_1 } \$
and if \$C_2 \gg C_1\$ we can define the following abbreviations:
\$ \omega_1 = \frac{1}{C_2\,R_2} \quad \text{,} \quad \omega_2 = \frac{1}{C_1\,R_2} \quad \text{,} \quad G_0 = \frac{R_2}{R_1} \$
This results in the bode plot as follows, wehere we can clearly see the two break frequencies \$ \omega_1 \$ and \$ \omega_2 \$.
Since I want to use the PLL for phase noise measurements, accurate frequency tracking is required, but the PLL should not affect the DUT's phase noise. I want a lower measurement limit of around 10 Hz, i.e. I want to measure the phase noise down to an offset from the carrier of approx. 10 Hz, up to perhaps 100 kHz. So \$ \omega_1 \$ needs to be much smaller than 10 Hz (say 3 Hz), and \$ \omega_2 \$ should be around twice the loop bandwidth, so probably 200 kHz? Why? I think inside the loop bandwidth the VCO is steered by the PLL, so in the range between \$ \omega_1 \$ and \$ \omega_2 \$ the phase noise measurement would be severely affected by the PLL, wouldn't it?
