I have PWM signal from a computer motherboard to control 2 fans, one of them is rated for 3000 RPM, and the other one is rated for 2000 RPM.
I'm trying to run all of them at the same speed(for example 1500 RPM) but I can only send one PWM signal, if I send PWM signal with 50% duty cycle one fan will run at 1500 RPM and the other will run at 1000 RPM.
So I was wondering if it is possible to take a PWM signal and modify it(Increasing duty cycle) and then feed it to one fan so that they run at the same speed.
Thanks in advance.
