I want to convert blind vias to through hole (4 layer board) like shown below:
th via
How do I do this?
    \$\begingroup\$ Delete the blind vias and add normal vias netted to the same places. \$\endgroup\$ – Andy aka Mar 15 at 11:30
It is quite simple:
  • Select the vias that you want to convert
  • Right click on it - Properties
  • Change the drill pair to Top Layer - Bottom Layer
You can also do the same operation from the PCB inspector
  • \$\begingroup\$ Thanks. This is the exact thing I was looking for. \$\endgroup\$ – Whiskeyjack Mar 15 at 11:45
  • \$\begingroup\$ Note that you can do a mass replacement by using 'find similar objects' \$\endgroup\$ – Peter Smith Mar 15 at 15:52
  • \$\begingroup\$ @PeterSmith - thanks for the tip. I have started using this tool very recently and being an eagle user, the options available with this tool feel overwhelming sometimes. :-) \$\endgroup\$ – Whiskeyjack Mar 16 at 5:41
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
