I'm using:
CCS V8
MSP430F2272
DSO-x 2024A Agilent oscilloscope
Trying to measure elapsed time between pulses with Timer B, Capture Mode.
My square wave source is at 50 kHz and my timer_b clock at 1 MHz (MCLK = 8MHz, SMCLK = 8MHz, ACLK = 1MHz)(code below)
P2DIR |= 0x08;
P2SEL |= 0x08;
TACTL = (TASSEL_1 | MC_1 | ID_1);
TACCR0 = 0x09;
TACCR1 = 0x05;
TACCTL1 = OUTMOD_6;
Source is as good as it could be... 50.001 kHz
P4DIR &= ~0x04;
P4SEL |= 0x04;
TBCTL = (CNTL_0 | TBSSEL_1 | MC_2 | TBIE);
TBCCTL2 = (CM_1 | CAP | CCIS_0 | CCIE | SCS);
To infer how many seconds have passed between events, the following formula is used:
(Over*65565 + Event_1 - Event_0)*0.000001
Where:
Over - Number of timer B overflows (how many times TBR has counted 0)
65565 - The size of TBR, defined by CNTL_0 bit
Event_1 - Value of TBR at the moment of the second event
Event_0 - Value of TBR at the moment of the first event
Below is presented my ISR:
__interrupt void Timer_B1(void)
switch( __even_in_range(TBIV,14) )
case 0: break; // No interrupt
case 2: break; // CCR1 not used
case 4:
TB_Pulse0 = TB_Pulse1;
TB_Pulse1 = TBCCR2;
TBCCTL2 &= ~CCIFG;
if(TB_Pulse0){
TBCTL = 0;
SendXBee |= TRUE;
break;
case 6: break; // CCR3 not used
case 8: break; // CCR4 not used
case 10: break; // CCR5 not used
case 12: break; // CCR6 not used
case 14:
TBCCTL0 &= ~COV;
if(TB_Pulse1)
OverFlo++; // overflow
break;
default: break;
As you can realize, from the code above, I'll only count timer overflows once the first event was been captured. When my second event is captured, timer b is turned off and I'll send data through UART.
My routine to send data, inside main, simply check the 'SendXBee', put all data through an XBee radio and reset 'Over', 'Event_1' and 'Event_0' variables.
Even this code looking fine (at least for me..) it does not work! Values read on the other radio give me measures about 1/10th of the real signal period.
Any suggestions? (Yeah!! stop working with embedded electronics.... just kidding)
Thanks everybody.
TB_Pulse0
/1
? Are you sure that the CPU runs fast enough to handle all events? \$\endgroup\$ – CL. Mar 15 '19 at 14:32
