Normally closed p-mosfet
Hi, I am trying to implement a normally closed switch. In the shown circuit:
Vcc = 16..60V (Vcc>>Vz)
The characteristics of the P-mos are: Vth = -1V Rdson = 0,055ohm
The circuit works correctly: in normal condition Vz=Vgs=-10V so the mos is fully opened. When the zener is shorted (using an optocoupler not shown in the circuit) the Vgs goes to 0 and the load (Vout) is de-energized. When a load is connected I have an 1V unexpected voltage dropout. When supplied with 15V and the load is 4Amps, I expected the following voltage dropout:
V = Rdson x Iload = 0,055 x 4 = 220mV
With a 1V dropout the equivalent Rds is:
R = Vds / Iload = 1/4 = 0,25ohm.. NOT 0,055
I suspect that the mos is not fully opened but I cant understand the reason
Thanks a lot
  • \$\begingroup\$ Have you measured the actual Vgs? It may be less than you think, since you're only putting about 6.6V/20k = 0.33 mA through the zener. \$\endgroup\$ – Dave Tweed Mar 16 at 21:42
