I have been working on a motion activated motor which uses a PIR sensor to detect the motion. The idea is when PIR detects user in front of it motor should start running and when the user moves away motor should stop.
Rev 3: enter image description here
Rev 2: enter image description here
The above circuit is the changes I have made in Rev 1 after valuable suggestions from Micheal. I have also added corresponding calculations for deciding the component value used in the above circuit.
I need to generate 1 sec time delay from PIR detecting motion and activation of motor. So
RC = 1 sec
Fixating the value of C as 10uF
R = 1 / 10 x 10^-6 R = 100k So the R1 value is 100k
Looking at capacitor charging curve a capacitor will charge 63% of applied voltage at time period T which is 1 sec. The output voltage of PIR sensor is 3.3v so 63% of 3.3 is 2.1v.
The voltage divider setup R3 and R2 values were chosen to give reference voltage as 2.1v . Did I make my calculations correct for what I intended to achieve ? I have also replaced the darlington transistor with N channel power MOSFET to drive the motor.
Rev 1: enter image description here
In the above circuit PIR sensor is used to detect humans. And I have used a RC circuit R1 and C1 to introduce some time delay in order to avoid false triggering. The load current of motor is 1A and I have used darlington transistor TIP122 to drive this motor.
The Vbe of TIP122 is about 2.5v as per the datasheet. And I wanted the delay from RC to be about 1sec. So it will take 1.5RC for capacitor to reach 2.6v across its terminal and at that instant transistor will get activated and drives the motor. So I have fixed the R1 value to be 67k and C1 value to be 10uF.
So my question is: Have I done the calculations right? Will my circuit work as intended?
If not any thoughts to achieve what was intended?
    \$\begingroup\$ The revised circuit looks much better than the original. Additional details to be considered. (1) Motor is an inductive load so fly back diode across motor is needed to cut spikes that can occur when the motor goes off. (2) It can be useful to add some hystersis to the comparator by adding some positive feedback via resistor from out to + input. This can reduce chance of oscillation when the input slowly crosses threshold. (3) Consider a diode and low value resistor path in parallel with R1 to discharge the capacitor more quickly when the sensor output goes low. \$\endgroup\$ Mar 20, 2019 at 7:07
  • \$\begingroup\$ Thank you for patiently suggesting improvements on the circuit. I have made the revision 3 with it, kindly take a look at it please. \$\endgroup\$ Mar 26, 2019 at 5:23
I suggest that to evaluate the correctness of your circuit design and your component value calculations that it would be useful to plug your circuit into a simulation program such as LTSpice to check its performance. If you do this before you build anything you can gain confidence that the circuit will give the response that you want.
In an application like you are attempting I would strongly suggest that you use an N-Channel MOSFET instead of the Darlington NPN transistors to drive the motor. This will give a high impedance at the gate so it is easier to design and get the timing delay circuit to work rather than the current bleed from the R/C part of the circuit that happens with the Darlington component.
Motors are inherently inductive and as such you will need to place a flyback diode across the motor leads to keep high voltage spikes from destroying the transistor when the motor goes off.
You may also want to consider introducing a voltage comparator between the R/C timing component and the motor driver transistor to be able to better set the delay timing threshold.
  • \$\begingroup\$ Thank you Michael for valuable suggestions. I have made the changes in circuit as per your suggestion. Also added calculations in it. Kindly take a look and advice me :) \$\endgroup\$ Mar 20, 2019 at 5:42
Some comments on version 3: an LM139 has open collector output so requires a pull up resistor to +5 ( or +12 which will mean almost any FET can be used ),1K or 2.2K would be good. For positive feedback to work you need a resistor between the capacitor and the plus input, 10K or so; now increase R4 to 1M. You can simulate the circuit to see the timing; you will probably want to decrease C1 and increase R5.
