Can you give me an advice what to do with probably overheated SMD soldering pads on the board?
The photo is of a computer bus card, where there are 4 SMD 0603 positions labeled R1 - R4. They are used for configuring the card frequency from 20 MHz to 40 MHz. These positions should be bridged by 0 ohm resistors.
I wanted to reconnect the R2 and R4 positions. I used a soldering station with iron and controlled temperature and electrical 1mm thin solder. I set the temperature to 350 degrees Celsius.
I didn't have SMD resistors, so I used just thin wire as I have seen in a web page. However it looks like I overheated the pads - they are a black color and I can't wet them any more with solder.
I know I should have better solder with hot air soldering unit and solder paste.
I found the same problem described in this forum thread http://eab.abime.net/showthread.php?t=76132 The guy there wanted to increase frequency from 33 MHZ to 40 MHZ on the card but he destroyed the pad like me. Then he found the right pins for R1 pads on ICS511 chip and reconnected the pins 6 and 7. I say ok, 33MHz should be enough. Now can you give me an advice how to solder two pins together ? Is it enough to use only small amount of solder or should i solder thin wire to the pins ? What about using the electrical conductive wire glue ? Or electrical conductive pen is enough ?
R1
andR2
have small parts of the1
and2
missing. It looks just like the whole track there has been pulled upwards, and taken the red solder resist and white silkscreen too, leaving just the bare fibreglass board where the track used to be. \$\endgroup\$
