I am working on a project and I use several PIC18F26K83's for this project. For communication between PIC's I use UART. Now I also need to send data with RS232 to the user. As I have understood the main difference between UART and RS-232 is voltage levels. And with PIC I cannot supply proper voltage level that is required for RS232. Because of that UART to RS232 converter's look like a must. (i.e. MAX232) I have two questions.
  1. Using UART to RS232 chips is the only option in this case? Are there any alternative ways?
  2. I am planning to send UART data directly to the UART to RS232 converter chip. I do not know how they work, code wise do I need to change anything? Can I directly put UART tx data to the receive pin of these chips? Thanks beforehand.
1) Using UART to RS232 chips is the only option in this case? Are there any alternative ways?
Of course, you can implement a level converter using discrete hardware. For instance, this site describes the following very simple circuit:
Please take care of the "operating notes".
No.
Yes.
  • \$\begingroup\$ Remember that this driver, like most you can buy, inverts between UART and RS232. \$\endgroup\$ Mar 19, 2019 at 13:42
  • \$\begingroup\$ Does that it does not invert RS232 to UART? \$\endgroup\$ Mar 19, 2019 at 14:09
  • \$\begingroup\$ That circuit won't meet RS232 specifications. It may often work, but only if connected to something that goes beyond specification. Use a chip that does it right with charge pumps, or the old way with extra power supplies. \$\endgroup\$ Mar 19, 2019 at 15:24
