My SNR is better with DC Free transmission. Why?
Example:
1.) Datasignal with DC:
Datastream consisting of 0V and 1V.
2.) Datasignal without DC:
Datastream consisting of -0.5V and 0.5V.
The variance is the same at both examples.
So I don't get, why the SNR is better without DC.
  • \$\begingroup\$ It's not as a rule, unless you are sensitive to 1/f noise, show your assumptions or real issue \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Mar 19 '19 at 23:08
Noise performance depends on the difference between levels. Since both your signals have a difference of 1 volt, they have the same resistance to noise.
However, they have different energy. Let's say that your data signal has a period of 1 second. Then, the pulses you transmit have the following energy:
  • The 0V pulse has energy 0 J.
  • The 1V pulse has energy 1 J.
Then, on average your signal requires 0.5 J per pulse.
The second signal uses pulses of the following energy:
  • The 0.5 V pulse has energy 0.25 J.
  • The -0.5 V pulse has energy 0.25 J.
So, on average the energy in this signal is 0.25 J per pulse.
So, removing DC results in a signal with the same error performance but less energy. This is equivalent to saying that you have a larger SNR.
(Note that I have made an assumption that is common in communications, that the load resistance is \$R_L = 1\,\Omega\$. In any case, when comparing the SNR of the two signals, \$R_L\$ cancels out, so its actual value is not important).
