My objective is to send a bit pattern of 1000 bits from one microcontroller (PIC or Atmel) to another one using the SPI method.
How can I visualize the bit pattern so I can find the errors of received bit pattern?
In Arduino serial monitor can be used for this. But I want to know a way for PIC or Atmel microcontrollers.
    \$\begingroup\$ This is usually done with a scope or logic analyzer. \$\endgroup\$ – Eugene Sh. Mar 20 '19 at 16:13
  • \$\begingroup\$ But it is not clear how you are going to send raw bits using SPI. SPI is usually having some kind of framing, grouping the bits into bytes or something. \$\endgroup\$ – Eugene Sh. Mar 20 '19 at 16:15
  • \$\begingroup\$ Just send a frame of bits that the receiver can recognize as being correct then it can self-flag if there is an error. \$\endgroup\$ – Andy aka Mar 20 '19 at 17:34
Get a usb logic analyzer they can be had for as little as 7$ USD .The bandwidth of the logic analyzer needs to be two times higher than the signal your observing. Logic analyzers set a threshold voltage and tell you if the signal is high or low (useful for digital).
Oscilloscopes allow you to see many different values (analogue) or a range of voltages, and can be useful for troubleshooting noise issues.
| improve this answer | |
