I'd like to know what type of cable this is. It looks very similar to the types used in phones and tablets and is for a camera. I need a replacement and would appreciate any help to locate the correct part.
Ribbon cable
Many thanks for your help.
    \$\begingroup\$ "FFC/FPC cable" is what you are looking for. One cut like that which is not straight is probably custom though. That might actually classify more as a flex PCB than FFC/FPC cable. \$\endgroup\$
    – DKNguyen
    Mar 20, 2019 at 19:28
    \$\begingroup\$ You might want to specify the equipment make and model from where this cable comes from, otherwise the chances of us suggesting were to find it are very slim. \$\endgroup\$
    – Elmesito
    Mar 20, 2019 at 19:39
    \$\begingroup\$ " I need a replacement" You could just fix the connections using wires. Check which one(s) is/are broken and bypass it/them. \$\endgroup\$
    – Oldfart
    Mar 20, 2019 at 19:40
    \$\begingroup\$ It's flex PCB, and it's custom made. So you're not going to be able to just swap out the whole thing unless you can get your hands on a the same make & model of equipment that's broken some other way than yours. \$\endgroup\$
    – TimWescott
    Mar 20, 2019 at 20:11
    \$\begingroup\$ Have you tried to contact the manufacturer of this SenseView Duo magnifier to see if they could send you a replacement part? Or looked on ebay for the same thing sold as "for parts"? Failing that, it would be simple, if kind of expensive, to draw up a roughly-equivalent flex pcb in KiCad and get it printed from a cheap PCB fab. \$\endgroup\$
    – Hearth
    Mar 20, 2019 at 23:31
Looks like a flex cable for phone battery. Contact manufacturer to get replacement cable or if someone makes it aftermarket. If replacing battery, flex cable comes with it.
