I am working project, using STM32F103C8T6 and W5500 Ethernet module. My project is something like network relay. My problem is that the STM32F103 can not boot up after pressing reset button when the BOOT0 jumper is on the position 0. But when I am pressing the reset button when the BOOT0 jumper is on the position 1, it resets successful, and removing old program from STM board. I' am using UDP to send and receive data over network connection.
Library I'm using for Ehternet module W5500 Ethernet_STM
Ethernet module: W5500 Ethernet module
STM board I'm usng: STM32F103C8T6
My sketch:
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet_STM.h>
#include <EthernetUdp.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <LiquidCrystal_I2C.h>
#include <EmonLib.h>
//write(0x00, 0x05, 128); // Software reset the W5500 chip
//line 333 in w5500.h    __SOCKET_REGISTER16(SnRX_WR,    0x002A)      // RX Write Pointer (supported?)
#if defined(WIZ550io_WITH_MACADDRESS) // Use assigned MAC address of WIZ550io
#else
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
#endif
IPAddress ip(192, 168, 0, 200);
IPAddress mydns(192,168,0,1);
unsigned int localPort = 8888;      // local port to listen on
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
EthernetUDP Udp;
EnergyMonitor enMonitor0, enMonitor1;
LiquidCrystal_I2C lcd(0x3F, 16, 2);
const int acVoltage0 = PA0;
const int acVoltage1 = PA1;
const int analogIn = PA3;
const int currentPin = PA2;
const int statusPin = PC13;
const int relay1 = PB0;
const int relay2 = PB1;
const int relay3 = PB3;
const int relay4 = PB4;
const float r_divider = 0.048122;
double V_AC0, V_AC1, Amps, voltageDC;
bool auth = false;
bool entering = false;
bool pchange = false;
char *key = "asdf";
void setup()
  Ethernet.begin(ip);
#else
  Ethernet.begin(mac,ip, mydns);
#endif
  Udp.begin(localPort);
  Serial.begin(9600);
  Serial.println("STARTED");
  disableDebugPorts();
  lcd.begin();
  lcd.backlight();
  pinMode(PB11, OUTPUT);
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  pinMode(statusPin, OUTPUT);
  pinMode(analogIn, INPUT_ANALOG);
  pinMode(currentPin, INPUT_ANALOG);
  digitalWrite(relay4, LOW);
  enMonitor0.voltage(acVoltage0, 227, 1.7);
  enMonitor1.voltage(acVoltage1, 227, 1.7);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(" -++=EDISON=++-  ");
  Serial.println("END of setup");
  //nvic_sys_reset();   //Reset STM32F103C
double measureVoltage_AC0()
  double V_AC;
  enMonitor0.calcVI(200, 2000);
  V_AC = enMonitor0.Vrms * 1.51;
  return V_AC;
double measureVoltage_AC1()
  double V_AC;
  enMonitor1.calcVI(200, 2000);
  V_AC = enMonitor1.Vrms * 1.51;
  return V_AC;
double measureVoltage_DC()
  uint16_t adcin;
  double voltage;
  adcin = analogRead(analogIn);
  voltage = 3.3 / 4095 * adcin;
  voltage = voltage * 20;
  return voltage;
double measureCurrent()
  uint16_t RawValue = 0;
  double Voltage = 0;
  double Amps = 0;
  RawValue = analogRead(currentPin);
  Voltage = (RawValue / 4095.0) * 5000; // Gets you mV
  Amps = ((Voltage - 600) / 60);
  if (RawValue < 50)  Amps = 0.0;
  return Amps;
void loop()
  Serial.println("loop");
  digitalWrite(PB11, LOW);
  delay(100);
  digitalWrite(PB11, HIGH);
  delay(100);
main:
  Serial.println("mAIN");
  V_AC0 = measureVoltage_AC0();
  V_AC1 = measureVoltage_AC1();
  voltageDC = measureVoltage_DC();
  Amps = measureCurrent();
  Serial.println("lcd.printing");
  lcd.clear();
  lcd.print(V_AC0);
  lcd.setCursor(7, 0);
  lcd.print("V");
  lcd.setCursor(0, 1);
  lcd.print(V_AC1);
  lcd.setCursor(7, 1);
  lcd.print("V");
  lcd.setCursor(10, 0);
  lcd.print(voltageDC);
  lcd.setCursor(15, 0);
  lcd.print("V");
  lcd.setCursor(10, 1);
  lcd.print(Amps);
  lcd.setCursor(15, 1);
  lcd.print("A");
  Serial.println(" end lcd.printing");
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  Serial.println(packetSize);
  if (packetSize)
    IPAddress remote = Udp.remoteIP();
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    if (auth == false && entering == false)
      Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
      Udp.write("Please Enter KEY");
      Udp.endPacket();
      entering = true;
    else if (!auth && entering)
      if (strstr(packetBuffer, key))
        auth = true;
        entering = false;
        Udp.write("Auth OK");
        Udp.endPacket();
    else if (auth)
      if (strstr(packetBuffer, "R1=ON"))
        digitalWrite(relay1, HIGH);
        Udp.write("K1 turned ON");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R1=OFF"))
        digitalWrite(relay1, LOW);
        Udp.write("K1 turned OFF");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R2=ON"))
        digitalWrite(relay2, HIGH);
        Udp.write("K2 turned ON");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R2=OFF"))
        digitalWrite(relay2, LOW);
        Udp.write("K2 turned OFF");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R3=ON"))
        digitalWrite(relay3, HIGH);
        Udp.write("K3 turned ON");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R3=OFF"))
        digitalWrite(relay3, LOW);
        Udp.write("K3 turned OFF");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R4=ON"))
        digitalWrite(relay4, HIGH);
        Udp.write("K4 turned ON");
        Udp.endPacket();
      else if (strstr(packetBuffer, "R4=OFF"))
        Udp.write("K4 turned OFF");
        Udp.endPacket();
      else if (strstr(packetBuffer, "MEASURES"))
        char ac1[10], ac2[10], dc[10], amps[10];
        dtostrf(V_AC0, 4, 2, ac1);
        dtostrf(V_AC1, 4, 2, ac2);
        dtostrf(voltageDC, 4, 2, dc);
        dtostrf(Amps, 4, 2, amps);
        Udp.write("VAC1 = ");
        Udp.write(ac1);
        Udp.write(" ");
        Udp.write("VAC2 = ");
        Udp.write(ac2);
        Udp.write(" ");
        Udp.write("VDC = ");
        Udp.write(dc);
        Udp.write(" ");
        Udp.write("A = ");
        Udp.write(amps);
        Udp.endPacket();
      else if (strstr(packetBuffer, "CHPASS"))
        pchange = true;
        Udp.write("Enter new KEY");
        Udp.endPacket();
        while (pchange)
          for (int i = 0; i < 24; i++)
            packetBuffer[i] = 0;
          int tmp = Udp.parsePacket();
          if (tmp)
            int len = 0;
              if (packetBuffer[i] > 0)
                len++;
            Serial.println(len);
            if (len != 4)
              Udp.write("Only 4 digit");
              Udp.endPacket();
            else
              key = packetBuffer;
              Udp.write("New KEY is: ");
              Udp.write(key);
              Udp.endPacket();
              pchange = false;
              goto main;
      else if (strstr(packetBuffer, "RESTART"))
        nvic_sys_reset();
      else if (strstr(packetBuffer, "LOGOUT"))
        auth = false;
        entering = false;
        Udp.write("Log out OK");
        Udp.endPacket();
  delay(10);
In my opinion this problem causes from the ethernet library, because when I comment the lines which contains the declaration of the objects which is members of this library, the reset function works good.
Any ideas or sulitions will be so good. :)
closed as unclear what you're asking by Chris Stratton, laptop2d, Finbarr, RoyC, JRE Mar 30 at 14:25
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Do you understand what the boot mode setting does, and why only one value would work? Though the required state is low, opposite of your seeming description unless that is a description of a physical position rather than a logical value. \$\endgroup\$ – Chris Stratton Mar 22 at 5:51
The BOOT0 pin on the "Blue Pill" doesn't have any shared functionality, so I'd be very surprised if the Ethernet module is having any effect.
The BOOTn pins have special meaning at reset, and the reference manual outlines how they are used. Look at Section 3.4, Table 9:
BOOTn Config
  • BOOT0 = 0 - the STM32 will boot from Flash Memory
  • BOOT0 = 1 and BOOT1 = 0 - the STM32 will boot from "System Memory" (i.e: the ROM bootloader)
  • BOOT0 = 1 and BOOT1 = 1 - the STM32 will boot from embedded SRAM
This contradicts what you're observing, so the first things I'd query are:
  • Did you put your binary into the STM32's flash memory, or did you load it into RAM?
  • How are you loading your binary? STLink?
  • The "Blue Pill" that you're using has both BOOT0 and BOOT1 on that 6-pin header, they should both be set to 0 - on the boards I have that is "close to the Micro USB connector", as pictured below.
Blue Pill Boot Mode
