I need help solving the following circuit using the Thevenin method:
The unknown in this problem is current i5, the correct answer is -1A.
I have already solved for the R(thevenin) by getting rid of all current and voltage sources and replacing them with either an open circuit or a short circuit, the resistance was correctly found to be 4 ohms.
However, I'm not quite sure how to calculate the V(thevenin)in order to reduce this circuit down to a Thevenin circuit. I have tried nodal analysis using node 1 and replacing the currents with differences in potential divided by the resistance but had no luck... any ideas on how to calculate Vth.
Thank you.
My mathematical approach so far:
Once all the dependent sources have been removed and replaced correctly, I see that (((R3+R4) || R6)||R2), calculating this gives ((20||10)||10) --> 4 ohms.
At node 1, I speculated that a current i1 might be going through the R4, the current source is giving a current of i2 = 1A and i3 is leaving the node through the remaining side, so i1+i2 = i3.
  • \$\begingroup\$ Can you show your mathematical approach, taken so far? \$\endgroup\$
    – jonk
    Mar 22, 2019 at 6:17
  • \$\begingroup\$ @jonk Any further edits which might help? \$\endgroup\$ Mar 22, 2019 at 6:25
  • \$\begingroup\$ I'm providing the first part of an answer below. Is this sufficient? \$\endgroup\$
    – jonk
    Mar 22, 2019 at 6:30
  • \$\begingroup\$ @jonk Is there any name for this method of analysis (the one with the vertically laid out circuit)? I want to look into it... \$\endgroup\$ Mar 22, 2019 at 6:35
  • \$\begingroup\$ See the rules I discuss here. As far as the idea of being able to assign \$0\:\text{V}\$ to any given (but only one given) node, that's more obvious. A schematic without a ground "floats" so to speak -- there are relative voltages, but no absolute voltage to any node. You can pick any one of nodes and give it an absolute value. This will tether (tie) all the other relative voltages to that value. Using the value 0 is a convenience. \$\endgroup\$
    – jonk
    Mar 22, 2019 at 6:41
You get to assign \$0\:\text{V}\$ to exactly one node in a circuit. I've chosen one in the following case:
Here, you can see there are only two nodal equations required by the circuit, so that means two equations and two unknowns. Once you know the value for \$V_\text{A}\$ you will know the exact value for \$I_5\$, as indicated in the diagram.
Thus:
$$\begin{align*} \frac{V_\text{A}}{R_1}+\frac{V_\text{A}}{R_2}+\frac{V_\text{A}}{R_3}+\frac{V_\text{A}}{R_4}&=\frac{10\:\text{V}}{R_1}+\frac{20\:\text{V}}{R_2}+\frac{0\:\text{V}}{R_3}+\frac{V_\text{B}}{R_4}\\\\ \frac{V_\text{B}}{R_4}+\frac{V_\text{B}}{R_5}&=\frac{V_\text{A}}{R_4}+\frac{0\:\text{V}}{R_5}+1\:\text{A} \end{align*}$$
Are you able to go from here?
(You could also just Thevenize your way through this without nodal analysis, I suppose.)
