I have a question, I want to measure a distance from an object of unknown shape and material, and I want to measure it under different angles, I want to measure a distance to just one specific point of object and accuracy has to be good.
Can someone please point me to right direction?
  • \$\begingroup\$ Not the right place to ask this question, please ask at robotics forum.Its very unlikely to get answer here. \$\endgroup\$ – perilbrain Oct 5 '12 at 8:55
  • \$\begingroup\$ Ok, tnx for informing me \$\endgroup\$ – Luka Pivk Oct 5 '12 at 9:00
  • \$\begingroup\$ Well, you can measure a 380 000 km distance with a 3 cm accuracy, will that do? I mean: what distance range and what accuracy are you thinking of? (The 3 cm accuracy is for measuring the distance earth-moon with a laser, it that would help.) \$\endgroup\$ – stevenvh Oct 5 '12 at 9:02
  • \$\begingroup\$ from 1cm to 50cm witch accuary down to 1mm \$\endgroup\$ – Luka Pivk Oct 5 '12 at 9:04
  • \$\begingroup\$ Laser inferometry? \$\endgroup\$ – pjc50 Oct 5 '12 at 9:35
A standard laser rangefinder (I have a Bosch DLE70) can give you 1.5mm precision from 5cm to many meters (mine works up to 70 meters) and works in daylight and for every texture and object I've tried.
Also look at this video
| improve this answer | |
  • \$\begingroup\$ Tnx, I will check the video when i am at home, btw: how fast can it measure? \$\endgroup\$ – Luka Pivk Oct 5 '12 at 11:25
  • \$\begingroup\$ DLE70 have a function that gives you a continuous distance reading, and IIRC it refresh display in less than a second. I can do a test tonight if you like, it's a function than I usually don't use. \$\endgroup\$ – Axeman Oct 5 '12 at 11:39
  • \$\begingroup\$ Can you please do the test and contact me over luka.pivk[at]avspekter.si. Tnx! \$\endgroup\$ – Luka Pivk Oct 5 '12 at 11:43
  • \$\begingroup\$ Done and mail sent. But I also report the results here. in my tests measures in the range 10cm-2m always took less than 0.7 seconds. \$\endgroup\$ – Axeman Oct 5 '12 at 20:46
