I am in the process of designing a PCB for a solder kit that receives NeoPixel type LEDs, the ones with the short head:
Short head NeoPixel
Now, there seem to be different pinouts:
Maybe someone can shed some light on this: Is there any system so that I can know when ordering which pinout I will get?
Update
I did a little bit more digging, which may answer the question. There seem to be two large manufacturs of the NeoPixel type THT LEDs with short head:
  • Worldsemi Co. Limited, making the WS2812D-F5 mentioned above:
    (DIN, GND, +5V, DOUT|
  • Shenzhen LED Color Opto electronic Co.ltd, making the SK6812D5 (datasheet) and the APA106:
    (DIN, +5V, GND, DOUT|
My take is that it’s best to order from vendors that clearly state the model number. Interesting is also the WikiLEDia list of chips sorted by manufacturer.
    \$\begingroup\$ If you want consistency you have to buy from actual distributors, not random deal importers. This questionnis off-topic here. \$\endgroup\$ – Chris Stratton Mar 23 '19 at 11:56
  • \$\begingroup\$ As said, the system applies to components just as well as it applies to cars, houses, fruit, meat, shoes and drugs: Reputable sellers will provide you with goods with a specification that actually applies. Other sellers shouldn't be getting your money. Full stop. I have zero sympathies for people getting scammed on aliexpress, amazon marketplace, or banggood. \$\endgroup\$ – Marcus Müller Mar 23 '19 at 13:05
  • \$\begingroup\$ @MarcusMüller nobody got scammed \$\endgroup\$ – feklee Apr 5 '19 at 9:26
