I'm planning to use an MCP4011-xxx/MC (DFN version).
This package has an exposed PAD. But nowhere in the datasheet, I can find the information if this exposed PAD should remain NC or tied to GND/VSS.
I used for other components DFN packages before and it was always mentioned, how the exposed PAD should be connected.
How the pad should be connected and where do I find this information? Can I assume that when it's not mentioned the default is connected to GND?
Datasheet
Microchip website
  • \$\begingroup\$ My advice is to ask Microchip directly. I don't see any reference to it in the datasheet either, but exposed pads are not usually left unconnected, as that would limit their usefulness for power dissipation. \$\endgroup\$ – Hearth Mar 23 at 14:13
  • \$\begingroup\$ The centre pad is listed as optional, so it would be safest to omit it, or leave it N/C. I have trashed a board iteration by connecting a pad to GND that should have gone to 'most negative' supply. However, this device is single supply rather than dual, so you might assume that it's OK to connect to ground. Do you need it for thermal dissipation? \$\endgroup\$ – Neil_UK Mar 23 at 14:13
    \$\begingroup\$ Although I agree with Hearth the best is to ask Microchip self, other Volatile Digital Potentiometer datasheets (e.g. MCP454X and MCP453X ) suggest: The DFN and QFN packages have a contact on the bottom of the package. This contact is conductively connected to the die substrate, and therefore should be unconnected or connected to the same ground as the device’s VSS pin. \$\endgroup\$ – Huisman Mar 23 at 19:47
  • \$\begingroup\$ @Neil_UK no, thermal dissipation is not an issue \$\endgroup\$ – KarlKarlsom Mar 24 at 2:57
  • \$\begingroup\$ then leave it off. \$\endgroup\$ – Neil_UK Mar 24 at 6:15
